Hi!
I was unsure where to put this topic. I've recently scanned a few of my burnt DVD media, movies only not data. I started to scan them using Nero CD-DVD speed. I have scanned them using the disc scan function and file test function. I have scanned about 5 discs so far and all of them are as follows:
Starting surface scan
Good: 99.90 %
Damaged: 0.00 %
Unreadable: 0.10 % (THE HIGHEST EVER HAS BEEN 0.11%)
Surface scan completed
The unreadable point is always the 'edge/tip' of the burn, never in the middle of the 'data'. I am not burning over the 4 GIG mark. The images I'm burning are all between 2.5GB and 3.7GB. I'm using Ridisc A Grade reel media with G04 dye. I've tried reading the burn back to the hard drive as an image using DVD Decryptor, works fine. The burns play fine also.
What is causing these unreadable errors? Should I be worried? I burn with DVD Decryptor. Also is surface scan of disc enough or is file test also advisable/cumpulsory?
Thanks!
Try another drive/computer. It sounds like the software/drive is pissing off the CPU when it starts to end the check cycle. What speed is this computer? I've seen this error before. Is it always on all discs you check?
Hi!
Thank you very much lordsmurf for replying. I was testing the discs using my Toshiba 1612 DVD ROM. I re-checked 3 of the 5 discs using my Pioneer 105 which were giving me these errors. They are now error-free. I just have 2 more to check and I'm quite sure that they are error-free as well. Changing the drive really helped.
Just one final question please. I am using NERO CD-DVD SPEED for testing burns. I am using the surface scan option under [menu] [extra] and checking the box [surface scan]. Is surface scan of disc enough or is file test also advisable/cumpulsory?. Any other options i should be using in NERO CD-DVD SPEED?
Thanks for the help.
Strange Anamorphic Results Megui not handbrake
By leftspeaker2000 in forum DVD RippingReplies: 27Last Post: 28th Jan 2012, 08:54 -
Strange remuxing results of AVI
By 201flyer in forum Video ConversionReplies: 0Last Post: 20th May 2010, 02:32 -
Something strange with speed/duration in Adobe Premiere
By Bouwe in forum EditingReplies: 0Last Post: 4th Jul 2009, 14:59 -
Strange DVD SPEED test results
By tac7 in forum DVD RippingReplies: 5Last Post: 2nd Apr 2009, 22:24 -
Speed Test Results
By HmNtr in forum Off topicReplies: 0Last Post: 28th Dec 2008, 02:58
