For those that doesn't know, when we capture realtime mpeg 2 with mainconcept 1.4.1 or 1.4.2 at a framesize less than 720 x 576/480, we have a picture distortion, like stuttering, at the bottom of the screen.
The only way I know to correct it (eliminate it), is to de-activate the "motion search pixel movement".
But this is not the best solution since I may not have stuttering, but I may have ghosting when something is moving on screen.
So I wonder, does anyone here figure out a better way to solve this issue? Or we have to wait the next version in case it is solved?
La Linea by Osvaldo Cavandoli
And BTW, what's your settings when you capture realtime mpeg 2?
One thing I recently noticed, is that when I set on the "multiplexer Settings" tab the option "Timestamps" on "I Frames", mainconcept became more CPU demanding than leave it on "All frames", while capturing
So, it seems that Mainconcept is not so popular after all...La Linea by Osvaldo Cavandoli
OK, let me try one last time:
Post the results of your tests here regarding the realtime mpeg 2 capture fuction. Which is your favorire set up and how you manage to succeed excellent results on your own?
Am I the only that actually use this program?La Linea by Osvaldo Cavandoli
Statstorm one question, have you tried VirtualVCR or PowerVCR? What are the problems with them? Im hearing that at least for avi capture VirtualVCR is ok.
KONX OM PANX -
This is not about avi capture (analogue / mpeg 4).
We talking about software realtime mpeg 2 capture!
For avi captures, both virtualdub and virtualvcr are excellent solutions!La Linea by Osvaldo Cavandoli
Video stuttering.
By reyerd in forum Software PlayingReplies: 12Last Post: 27th Mar 2011, 05:07 -
Problem with XMedia Recode (2.3.0.9). Video stuttering.
By smackyourfupa in forum Video ConversionReplies: 2Last Post: 26th Feb 2011, 19:16 -
EasyCAP w/ Ulead and Pinnacle - Video Stuttering/Jumping/Lagging problem
By Logan289 in forum Capturing and VCRReplies: 0Last Post: 30th May 2010, 15:25 -
Stuttering mpeg
By GerryJ in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 3rd Feb 2010, 21:23 -
Mainconcept encoding problem - Audio
By Mysteriouskk in forum Video ConversionReplies: 0Last Post: 25th Nov 2007, 10:25
