When i play some Xvid movies with fast scenes the picture gives stipes.
Like some kind of slow motion.
How can I prevent this.When converted to mpg this is still there.
I've installed directx9.0c, Xvid latests, no problems with audio
Someone to help???
Trenchy
You could play them with another player, or De-Interlace them (requires reencode).
PowerDVD will deinterlace during playback.
If converting with an encoder like TMPGEnc you have to tell it if your source video is interlaced. Using the "Project Wizard", TMPGEnc can detect if your source is interlaced.
If converting to VCD you should probably just deinterlace through TMPGEnc (or whatever your using). If converting to DVD you should NOT deinterlace, but set source as "Interlaced". Attention should be payed to the "Field Order" when encoding interlaced video (Project Wizard can also detect this).
Encoding in XVID causes horizontal stripes on standalone player
By deadp0et in forum Video ConversionReplies: 12Last Post: 23rd Nov 2011, 20:41 -
Fast moving scenes show multiple images
By Acg in forum Authoring (Blu-ray)Replies: 3Last Post: 20th Jun 2010, 18:00 -
Gui dvd author-jumping movie in fast motion scenes due to high video bitrat
By extent in forum Authoring (DVD)Replies: 8Last Post: 19th Feb 2009, 08:30 -
FAST convert to Divx or Xvid
By nerys in forum DVD RippingReplies: 23Last Post: 2nd Oct 2008, 01:30 -
Fast simple way to resize Xvid
By Maxwellbest in forum Video ConversionReplies: 8Last Post: 2nd Feb 2008, 18:32
