Im still no wiser as to why after burning avi to dvd using the above tools the sound is ok but the picture is just a black screen with red fuzz at the bottom.
I was told to make sure the codecs where pointing to the right files but im not very wise when it comes to codecs so im not sure what to do.
Ive got the film machine pointing to CCE correctly so it should work shouldnt it?
Results 1 to 16 of 16
can you play the avi file ?
some of the settings in The Film Machine for CCE are a little odd i found -- but its a handy program ..
i never could get it to make the IFO files and don't reduce CCE to your system tray or film machine will not work .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
sometimes it plays and sometimes it doesnt.
do you know the best tools to use for novice converters like myself where you just drag ure avi files in and click go -
Read my answerOriginally Posted by krspa9
EDIT
This thread describes your problem and how it was resolved in DVD-Rebuilder. It may be applicable to your situation with The Film Machine. -
Hi all. Although I managed to create a dvd from a divx downloaded movie (last night), I tried to do another movie again this morning (using The Film Machine with QuEnc as I do not have the other encoding softwares) but the process failed with the following error:
FAILED ON AVS LOAD
ERROR CODE 2147221164
DOES THE FILE ….TFM_Avisynth_Script_File.avs EXIST?
I ran the divx movie through DivFix to look for any errors on the original but there were no errors reported.
I then uninstalled The Film Machine and QuEnc softwares, reinstalled them and tried to turn the dvix movie into a dvd. This time I got the following error:
AVS FILE IS NOT OUTPUTTING
(USE CONVERT TO YV12() AT END OF SCRIPT)
Does anyone know what is going wrong
Any help much appreciated.
Thank you. -
The .AVS files are scripts generated by The Film Machine to frameserve your QuENC encoder.Originally Posted by meera shah
The first message indicates that the .AVS file was either not created or created in a folder not defined to TFM.
The second message indicates that the .AVS file needs this line
CONVERT TO YV12()
added at the end. You can use Notepad to edit the file. I don't use TFM so I can only give you general advice. TFM will create new .AVS scripts when you start it so you will have to somehow stop TFM during the encoding phase, substitute the new AVS script and then restart TFM. -
Thank you for the reply jyn999. It shows that you understand the error codes but I am a newbie with TFM and do not know how to go about rectifying the problem by creating the AVS file in TFM and also how to add CONVERT TO YV12() at the end of the AVS file. The software worked smoothly first time yet failed me the second time I tried it. The first time I did not have to create any AVS file nor add CONVERT TO YV12() at the end of any file names. I hope to get some help here from someone who uses TFM and can help me rectify the problems. Thank you for the insight into the errors though jyn999.
try reinstalling it
I just installed TFM and went through the various screens. After you select the source AVI file, the very next screen has a check box for Edit AviSynth script file. Select it and a window will pop up when the encoding phase starts. Make your changes to the .AVS script file, click save (or OK) and encoding should continue with the new script file.Originally Posted by meera shah
jyn999....thank you for your reply.
I did the following as you said:
After selecting the source AVI file, I checked the Edit AviSynth script file box.
I clicked on Next.
Here I made my DVD size choice and gave a title to the movie.
I clicked on Next.
I left the subtitle window as it is and clicked on Next.
I then got the window The Film Machine (Version 1.3) with no Next button highlighted but Make DVD button highlighted.
I clicked on Make DVD.
The following message came up:
- 16/10/2004 13:48:14
- AVI to DVD conversion
- The FilmMachine version 1.3
Initializing.
Initializing finished.
Then nothing happened! No encoding phase started and there was nowhere to make changes to the AVS script file like you advised me.
I apologise for giving you yet more trouble with my trouble! Thank you for any help you may be able to assist me with. -
@meera shah,
My replies were based on my experience using DVD2SVCD. Other than installing The Film Machine and running through the screen, I have zero experience with it so I won't be able to help you resolve your current problems.
Why don't you download DVD2SVCD and give it a shot?
Good luck. -
jyn999...thank you for your reply. You advised using DVD2SVD. Would that be suitable to turn a DivX movie into DVD?
Your advice much appreciated.
Thank you. -
Yes. You go into the MISC tab and select .AVI files as the source.Originally Posted by meera shah
EDIT
I forgot you're not the original poster of this thread. DVD2SVCD uses Cinema Craft Encoder, TMPGEnc , or Canopus ProCode as the encoder. If you don't have one of these, then DVD2SVCD is not suitable for you.
EDIT
DVD2SVCD version 1.2.2 build 2 and later can use QUEnc.
Sorry about any confusion. -
jyn999...hi again
With regards to DVD2SVD 1.2.2, can I download this for free? I already have QUEnc on my system. With those in place, then I can perhaps turn the DiVx movie into a DVD?
Thank you for your assistance.
[quote="meera shah"] With regards to DVD2SVD 1.2.2, can I download this for free?
Yes. Look to the left, click Tools and search for DVD2SVCD.
I've used DVD2SVCD to create DVDs from AVIs but I used CCE not QUEnc. Look in the Doom9 forums for advice on DVD2SVCD.
Cinema Craft Encoder Sp 2.67.00.27
By Gwar in forum Video ConversionReplies: 1Last Post: 19th Feb 2012, 11:32 -
Cinema Craft Encoder Picture Quality
By pboong in forum Video ConversionReplies: 5Last Post: 23rd Aug 2010, 23:17 -
NEW VERSION: Cinema Craft Encoder SP2 1.00.01.01
By devilcoelhodog in forum Latest Video NewsReplies: 10Last Post: 18th May 2008, 11:46 -
Help with Cinema Craft Encoder
By Topcat360 in forum Video ConversionReplies: 31Last Post: 29th Jan 2008, 16:51 -
Cinema Craft Encoder Plugin
By MI6 in forum Video ConversionReplies: 1Last Post: 11th Aug 2007, 18:05
