I've been authoring for awhile with no problems, all of a sudden out of nowhere, my burner decided it didn't like DVD-Rs. I could write to +R and +RW with no trouble, but it wouldnt write to -R or -RW anymore. I tried several different media and several different burning programs but couldnt fix it. I bought a new burner, and all went well for 4 months but now the same thing has happened again. I really need some help with this.
Here's the burn log from nero ...
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 7/17/2002 10:03:20 AM
ahead WinASPI: File 'C:\Programs\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.68, size=160016 bytes, created 7/22/2004 5:33:44 PM
Nero version: 6.3.1.20
Recorder: <_NEC DVD_RW ND-2500A> Version: 1.06 - HA 3 TA 0 - 6.3.1.20
Adapter driver: <> HA 3
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <AOPEN 16XDVD-ROM/AMH >Version: R13 - HA 1 TA 0 - 6.3.1.20
Adapter driver: <atapi> HA 1
=== Scsi-Device-Map ===
DiskPeripheral : Maxtor 6Y060L0 atapi Port 0 ID 0 DMA: On
DiskPeripheral : Maxtor 6E040L0 atapi Port 0 ID 1 DMA: On
CdRomPeripheral : AOPEN 16XDVD-ROM/AMH atapi Port 1 ID 0 DMA: On
DiskPeripheral : ST3160021A atapi Port 1 ID 1 DMA: On
CdRomPeripheral : Generic DVD-ROM 1.0 d343port Port 2 ID 0 DMA: Off
=== CDRom-Device-Map ===
AOPEN 16XDVD-ROM/AMH G: CDRom0
Generic DVD-ROM H: CDRom1
_NEC DVD_RW ND-2500A I: CDRom2
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 1023MB (1048048kB)
Free physical memory: 682MB (698480kB)
Memory in use : 33 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
8.10.2004
UDF/ISO compilation
1:35:43 PM #1 Phase 112 File dlgbrnst.cpp, Line 1855
DVD-Video files reallocation started
1:35:43 PM #2 Phase 114 File dlgbrnst.cpp, Line 1855
DVD-Video files reallocation completed (no file modified)
1:35:43 PM #3 Text 0 File Isodoc.cpp, Line 6065
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 2 (Max. of 31 chars)
Character set : ISO 9660
Joliet :FALSE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
1:35:43 PM #4 Phase 111 File dlgbrnst.cpp, Line 1855
DVD-Video files sorted
1:35:43 PM #5 Text 0 File Reader.cpp, Line 126
Reader running
1:35:43 PM #6 Text 0 File Writer.cpp, Line 124
Writer _NEC DVD_RW ND-2500A running
1:35:43 PM #7 ISO9660GEN -11 File geniso.cpp, Line 3899
First writeable address = 0 (0x00000000)
1:35:43 PM #8 ISO9660GEN -11 File geniso.cpp, Line 3899
1:35:43 PM #9 Text 0 File Burncd.cpp, Line 3173
Turn on Disc-at-once, using DVD media
1:35:43 PM #10 Text 0 File DlgWaitCD.cpp, Line 247
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2286127 (508:01.52, 4465MB)
1:35:43 PM #11 Text 0 File DlgWaitCD.cpp, Line 259
Write in overburning mode: NO (enabled: CD)
1:35:43 PM #12 Text 0 File DlgWaitCD.cpp, Line 2162
Recorder: _NEC DVD_RW ND-2500A, Media type: DVD-R
Disc Manufacturer: PRINCO -
Disc Application Code: 64, Disc Physical Code: 193
1:35:43 PM #13 Text 0 File DlgWaitCD.cpp, Line 420
>>> Protocol of DlgWaitCD activities: <<<
1:35:43 PM #14 Text 0 File ThreadedTransferInterface.cpp, Line 813
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 2286128 (2286128) = #2286128/508:1.53
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286128 blocks [_NEC DVD_RW ND-2500A ]
1:35:43 PM #15 Text 0 File ThreadedTransferInterface.cpp, Line 984
Prepare recorder [_NEC DVD_RW ND-2500A ] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4681990144, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
0 | lead-in | 0 | 0x00 | 0x41
0 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
2286128 | lead-out | 1 | 0x00 | 0x41
1:35:44 PM #16 Phase 24 File dlgbrnst.cpp, Line 1855
Caching of files started
1:35:44 PM #17 Text 0 File Burncd.cpp, Line 4183
Cache writing successful.
1:35:44 PM #18 Phase 25 File dlgbrnst.cpp, Line 1855
Caching of files completed
1:35:44 PM #19 Phase 36 File dlgbrnst.cpp, Line 1855
Burn process started at 2x (2,770 KB/s)
1:35:44 PM #20 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
1:35:44 PM #21 Text 0 File dlgbrnst.cpp, Line 1713
Set remaining time: 28:15,558 (1695558ms) -> OK
1:35:44 PM #22 Text 0 File DVDR.cpp, Line 1942
Recording mode: Sequential Recording Mode
1:35:44 PM #23 Text 0 File Mmc.cpp, Line 20531
Set BUFE: supported -> ON
1:35:44 PM #24 Text 0 File DVDR.cpp, Line 2083
Start write address at LBA 0
DVD high compatibility mode: Yes
1:35:44 PM #25 Text 0 File Cdrdrv.cpp, Line 8128
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26127F h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 2FE10 h
Start sector number of the next Border-In: 2FFA0 h
Media Specific [16..63]:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ................
1:35:46 PM #26 Text 0 File Cdrdrv.cpp, Line 1294
13:35:46.140 - _NEC DVD_RW ND-2500A\H3 T0 : Queue again later
1:35:51 PM #27 SCSI -500 File Cdrdrv.cpp, Line 1442
SCSI Exec, HA 3, TA 0, LUN 0, buffer 0x03A40000
Status: 0x02 (0x03, SCSI_ABORTED)
HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED)
TA-Status 0x00 (0x00, OK)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x26
Sense Qual: 0x02
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x26 0x02
1:35:51 PM #28 CDR -500 File Writer.cpp, Line 304
SCSI command aborted
1:35:51 PM #29 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
1:35:51 PM #30 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
1:35:51 PM #31 Text 0 File DVDR.cpp, Line 2325
EndDAO: Last written address was -1
1:36:38 PM #32 Text 0 File dlgbrnst.cpp, Line 1713
Set remaining time: 0:00,000 (0ms) -> OK
1:37:08 PM #33 CDR -1175 File Cdrdrv.cpp, Line 1246
Internal trace
Resending of command failed after 30000ms
CDB Data[hex]: 55 10 00 00 00 00 00 00 3C 00 00 00
1:37:08 PM #34 SCSI -1169 File Cdrdrv.cpp, Line 1247
SCSI Exec, HA 3, TA 0, LUN 0, buffer 0x0012AE88
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x02 (KEY_NOT_READY)
Sense Code: 0x04
Sense Qual: 0x08
CDB Data: 0x55 0x10 0x00 0x00 0x00 0x00 0x00 0x00 0x3C 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x02 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x04 0x08
ModeSel: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
0x05 0x32 0x02 0xC4 0x08 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x96
0x00 0x00 0x
1:37:38 PM #35 CDR -1175 File Cdrdrv.cpp, Line 1246
Internal trace
1:37:38 PM #36 SCSI -1169 File Cdrdrv.cpp, Line 1247
Sense Code: 0x04
Sense Qual: 0x08
0x05 0x32 0x01 0xC4 0x08 0x00 0x00 0x00
0x00 0x00 0x
1:37:38 PM #37 CDR -1169 File WriterStatus.cpp, Line 164
Logical unit not ready, operation in progress
1:37:38 PM #38 TRANSFER -24 File WriterStatus.cpp, Line 164
Could not perform end of Disc-at-once
1:38:08 PM #39 CDR -1175 File Cdrdrv.cpp, Line 1246
Internal trace
1:38:08 PM #40 SCSI -1169 File Cdrdrv.cpp, Line 1247
SCSI Exec, HA 3, TA 0, LUN 0, buffer 0x0012B028
Sense Code: 0x04
Sense Qual: 0x08
0x00 0x00 0x
1:38:38 PM #41 CDR -1175 File Cdrdrv.cpp, Line 1246
Internal trace
1:38:38 PM #42 SCSI -1169 File Cdrdrv.cpp, Line 1247
Sense Code: 0x04
Sense Qual: 0x08
0x00 0x00 0x
1:38:38 PM #43 Text 0 File dlgbrnst.cpp, Line 1713
1:38:38 PM #44 CDR -1169 File WriterStatus.cpp, Line 169
1:38:38 PM #45 TRANSFER -39 File WriterStatus.cpp, Line 169
Could not perform EndSession
1:39:08 PM #46 Phase 38 File dlgbrnst.cpp, Line 1855
Burn process failed at 2x (2,770 KB/s)
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=6.2.0.110 , size=24698 bytes, created 9/26/2004 10:57:16 PM
File 'Drivers\ASPI32.SYS': Ver=4.71 (0002) built by: WinDDK, size=16512 bytes, created 7/17/2002 9:05:10 AM
File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 5/11/2004 9:34:28 PM (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 8/29/2002 4:27:50 AM (Adapter driver for src)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Results 1 to 10 of 10
get a new burner
not a authoring issue either - moving it ..
Nero worked, copytodvd worked, Roxio worked, many of them worked, but now none of them do... I've reinstalled nero many times, and it still won't work anymore, it doesn't seem to be the programs, doesn't seem to be the media and doesn't seem to be the burners... I'm desperate here.
btw, my 1st burner was a pioneer.. my current one is NEC 2500A... same problems with both burners.... -
Can you still burn to CD but not to DVD? If you answer yes then I would say your laser is faulty. It happened to me with NEC 1300 4x. I presently have a NEC 2510A and NEC 3500AG now and they are great. If no burning programs can burn to DVD that you probably have a shot laser. That is if you can still burn to CDs.
I could be off on this but mine did that very thing without one iota of warning. I burned a DVD perfectly and them it would not recognize the precence of any type of DVD disk or store bought Movie disk immediately afterwards.No DVD can withstand the power of DVDShrink along with AnyDVD! -
well, thats the odd part... I can still write to CDs, DVD+R and DVD+RW ... it just won't write to DVD-R or DVD-RWs anymore.
Maybe a problem with Windows ?
Did you try format c: and reinstall Windows ? -
I've just finished reinstalling windows and tried it again with just the basics + nero and still get the same problems. And no, my first drive was a pioneer... the current one is NEC.
How to author a dvd from several xvid movies without sync problems
By rickywh in forum Authoring (DVD)Replies: 2Last Post: 8th Apr 2010, 15:02 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 20:33 -
Problems when I try to add subtles in my video on TMPG DVD Author 3
By ihmcjacky in forum Authoring (DVD)Replies: 4Last Post: 22nd Mar 2008, 02:24 -
TMPGenc DVD Author 3 Sound Problems
By wapdoggie in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2007, 17:00 -
Problems with TMPGEnc DVD Author 3 and multiple AVI files
By cadkins in forum Authoring (DVD)Replies: 6Last Post: 9th May 2007, 15:37
