Dear All,
After having tried everything that I could, here I am humbly asking for assistance.
I currently have two manners to go from original material to DVDs, either digitizing analogue material, manipulating, authoring and burning to DVD, or via my Sony DVD-Recorder.
In either case there are situations where I would like to take an existing DVD that I created and convert it back to either no sound AVI and WAV or even just a normal AVI.
I have tried everything that I could find but am unable to do it satisfactorily. Latest attempt was by using IMTool DVD-Ripper to get the VOBs on my hard drive but I am then unable to convert these back to AVI.
Any kind soul who could help?
Thanks in advance and best regards.
Massimo.
Try Virtual Dub mod. Load the VOBs into it, select the codec, and Save As AVI... to your new AVI file name.
Hello. -
Thanks Tommy,
Would I also be able to change resolution and/or frame rate at the same time if I needed to (i.e. PAL to NTSC)?
Can this generate separate video (mute video in the AVI file), and audio (WAV), files?
Massimo. -
You can change the resolution with the Resize filter. Select File=>Save Wav to get your wave file. Frame rate can be changed by selecting Video=>Frame Rate.
Hello.
[urgent help needed] audio decoding error
By dc0yy in forum Video ConversionReplies: 2Last Post: 26th Aug 2011, 12:47 -
Problem decoding DVDs, Pineapple Express, My Best friend's Girl, etc
By jiffymc in forum DVD RippingReplies: 8Last Post: 20th Jan 2009, 12:44 -
ADVICE needed plz! As of Feb 08, best format to ripp DVDs? TIA.
By carapalida in forum Newbie / General discussionsReplies: 3Last Post: 13th Feb 2008, 11:11 -
ADVICE NEEDED... as of today, what is BEST vid format to convert DVDs???
By carapalida in forum Video ConversionReplies: 4Last Post: 7th Oct 2007, 16:39 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30
