What causes the "noise" in a ripped movie? Is there a way to find such "disturbances in the force" without watching the whole ripped movie again?
Results 1 to 11 of 11
+--Prince Of Thieves
+--[ DVD Backup Experience =>
+--"I've now ripped a few more coasters!"
Did you SHRINK it?
No. I just used DVD Decrypter to rip it to the HDD and then played the resulting ISO using my virtual DVD/CD drive. The "noise" is always in the same spot and lasts for about 1 second and so far happens about four times thru out the movie.
Thanks|
Does this noise is green or multicolored squres ??
If yes, it seems like a damaged mpeg file (read from a scratched disk). -
And the noise isn't on the original dvd? Could you post a screenshot(using powerdvd or windvd or media player classic)
The "noise" is multi-coloured squares. Here's a screenshot:
You'll notice the head of the maid on the right of the gentleman is messed up along with the head of the girl on the right of the shot.
Is there any way to detect such glitches albeit watching the whole ripped movie?|
You're hitting a fragmentation on the file. Or the system resources cannot keep up (RAM, CPU).
Thanks, but can it really be a systems resource problem? I'm running a WinXP SP2, 160 GB RAID1, P4-3.2GHz, 1GB RAM system.
Is there a utility which can check if this has happened anywhere else in the movie without viewing the whole movie again?
TIA|
When you say the errors occur on the same spot it's just the disk which is damaged or cannot be read correctly.Originally Posted by thief_
File fragmentation or system resources are no issue here. Better try it in another DVD reader if possible.
Also check the I/O settings in the dvddecrypter settings and make sure the ignore read errors option is off. -
Which DVD player are you using.
With PowerDVD 5 I had always this artefact. Switching back to version 4 resolves all the problems.
Maybe it's the same for you.
Look at this thread (the PDVD 5 bug is well visible): https://www.videohelp.com/forum/viewtopic.php?t=165610
this one is more visible: https://www.videohelp.com/forum/viewtopic.php?t=173484
MacTheRipper - "Untitled Project" Subtitle on Ripped Results
By ramseytheii in forum MacReplies: 2Last Post: 17th Jan 2011, 13:56 -
Deleting or softening a "creaking" noise in recital audio in Audacity
By MLK3329 in forum Video ConversionReplies: 5Last Post: 9th Oct 2010, 16:41 -
DVD with menus, replacing "bad" video with "good" video
By chipsndukes in forum Authoring (DVD)Replies: 34Last Post: 4th Dec 2008, 18:45 -
Why do I have 2 files? "Movie Clip" and "M2V File"
By tygger in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jun 2007, 22:55 -
S-Video capture produces "crosshatch" noise
By scootdogg in forum Capturing and VCRReplies: 11Last Post: 4th May 2007, 12:53
