  1. Member geohei's Avatar
    May 2002
    Luxembourg
    Hi.
    When encoding video/audio with TMPGEnc, it offers 3 possibilities for stereo MP2:
    1. Stereo
    2. Joint-Stereo
    3. Dual channel
    - What is the optimum (quality wise), when space is not an issue?
    - What are the differences.
    Many thanks.
    Australia
    I've wondered about that too - so I went searching the web and found this explanantion.
    Stereo has 2 seperate channels, but the bitrate allocation between those two channels changes accordingly to the amount of information there is in each channel.
    Joint stereo has 2 channels, but takes advantage of what is common between the channels, so the compression gain is higher.
    Two of the most used joint stereo modes are IS (intensity stereo) and M/S (Mid/Side). M/S matrixing computes the sum and the difference of the two audio channels and stores these as two channels. This method is very efficient and is a lossless process, which means the two original channels can be extracted exactly as they were.
    Intensity stereo replaces the left and right channels with a single signal plus directional information. This method is lossy and destroys DPL information. This method is only recommended at low bitrates.
    Many encoders can use a combination of full stereo and either or both of these methods, deciding which to use on a per-frame basis.
    Dual channel has 2 mono-channels, meaning each channel is encoded with half the bitrate of the overall bitrate.
    It would seem from this that plain 'Stereo' is the best option to use.
  3. Member geohei's Avatar
    May 2002
    Luxembourg
    ... seems to be.
    Thanks a lot for the investigation
