Is there a way to take a wav file, convert it to AC3 and then have it play on a DVD and sound like surround sound? I know you can't really convert it to 5.2 but is there a way to manipulate it to sound similar? A program that wolud do it perhaps?
Phil in Montana
This is a method I have used successfully in the past. It will not give you a sound field as good as one generated from scratch, but for music or dance clips, it can be very effective. This ethod is based on the following software
Vegas Video 5 with AC-3 plugin
Sound Forge 7 (any version from 5 up will do)
Vocal Remover (free DX plugin from Analog-X)
In Vegas, make sure your project is set to 5.1 AC3 audio. On each audio track in the editor you should see a small box with a red dot in the middle. This represents the percieved source of that track in the sound field. All you have to do is move the dot around to change the position and relative volume of the track.
If you haven't already, I would suggest breaking your tracks in Vegas into individual tracks to give you individual control. When I have found myself doing similar work, I break the track down into left and right, a combined centre, a copy of centre for the lfe, and a vocal stripped version for the rears. I use Analog-X's Vocal Remover in sound forge to create this.
The output will never be a sophisicated as a 5.1 mix done from scratch, but the results can be pleasing to the ear if done carefully.Read my blog here.
"If you haven't already, I would suggest breaking your tracks in Vegas into individual tracks to give you individual control. When I have found myself doing similar work, I break the track down into left and right, a combined centre, a copy of centre for the lfe, and a vocal stripped version for the rears. I use Analog-X's Vocal Remover in sound forge to create this."
What the hell is LFE? -
Low Frequency Effects - AKA the point 1 in 5.1What the hell is LFE?
The rumble in the jungle.
The thump after the jump. :P -
LFE drives the sub-woofer, although it is not strictly necessary as there is also a frequency cut off used to drive it as well. This is set in the amp. Many studio releases do not have an LFE track because there is enough to work with in the other channels.
Read my blog here.
Thanks... I know what Low Frequency Effects are though... man, am I a moron!!
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 07:39 -
6 wav to DVD with surround sound
By kkkkamy in forum Authoring (DVD)Replies: 7Last Post: 8th Feb 2010, 16:30 -
Weird echo on DVD-Rs with Dolby Stereo Surround VHS sources
By ministry88 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 20th Feb 2009, 23:47 -
Converting WAV file to Dolby Digital® 5.1 Surround
By roma_turok in forum User guidesReplies: 18Last Post: 16th Nov 2008, 22:32 -
Dolby Digital Surround EX encoder
By grasswhopper in forum AudioReplies: 1Last Post: 17th Aug 2007, 23:49
