Results 1 to 9 of 9
    Sep 2004
    Drumnadrochit, Scotland
    ok since theres an increasing amount of spybots and viri on the internet ive decided to format for the GaZillianth time and start again....
    does anyone have any reccomendations of what firewall or anti virus to run whilst surfing....
    preferably a free one such as AGV!
    stuartmoffat.com ~
  2. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    I use Zonealrm... www.zonelabs.com, free for just the firewall. Make sure you download and install it before going on the net. Or some other product, the firewall is important.
    I'm running Mcafee 2004 as my virus protection, no complaints. I've heard nothing negative about AVG just praise.
    You should also get some good spyware apps, ad-aware www.lavasoftusa.com and spybot (do a search) top the list. Both free
    Sep 2004
    thanks very much coalman, gona get ZA and AGV now , I will probably end up getting Adaware to but Ive just formatted today so im not realy worried about spyware just now,
    thanks again
    stuart
    stuartmoffat.com ~
  4. Member glockjs's Avatar
    Feb 2004
    the freakin desert
    get firefox browser www.mozilla.org then you really wont have to worry about spyware at all
    PhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500
    Sep 2004
    yeah I just pm'd BJ about that, I asked him if there was less a risk of spyware with firefox but no reply yet, I guess Ill just download it, thanks glock
    stuartmoffat.com ~
  6. Member thecoalman's Avatar
    Feb 2004
    Pennsylvania
    Running a unpatched version of XP on the net without a firewall is opening it up to many malicious viri. When I say on the net I mean simply connecting, that's all you need to do. At the very least I hope you had the XP firewall running.
    When reinstalling XP my advice has always been, first install a good firewall and your virus protection before connecting. Immeditley install all the critical updates from MS after connecting.
  7. Member mastersmurfie's Avatar
    May 2003
    just my personal preference, but I use AVG anti-virus--along with Outpost Firewall-no problems whatsoever...
    also run Spybot and Ad-Aware every so often...
    EDIT: also running firewall built into XP SP2...
    mastersmurfie
    just a thought
    mastersmurfie
  8. Member glockjs's Avatar
    Feb 2004
    the freakin desert
    watch out for sp2 though. been hearin alot of probs. im personally waiting for sp3.
    oh yeah, im usin ZA pro for fire wall. works pretty good. as far as my anti virus nortorn corp edition. free for me not for u
  9. Member mastersmurfie's Avatar
    May 2003
    I was reluctant at first to do the SP2 thing too...even had problems getting it in the first place...but after installing, still no problems at all...
    I too *used* to use a "free for me" version of norton...in the end, it caused my W98 to completely crash...so found the free AVG~been using it ever since...
    mastersmurfie
    just a thought
    mastersmurfie
