vts_0a_0b.vob
a = the track number
b = the chapter number
now if I have some .vob files that are
vts_01_01.vob
vts_02_01.vob
If I wanted to go ahead and change the tracks to chapters can I go ahead and change a to 1 and b to the corressponding chapter number without having any problems?
Hi boogie-pop,
Try it - burn it to a re-writeable and see. But I doubt it...
I'd guess you'll have to re-author. Something like TMPGEnc DVD Author accepts VOBs and will allow you to set tracks and chapters as you want. DVDLab will probably do the same, and I'm sure there'll be other apps too...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
b usually isn't the chapter number, simply the number of the vob file for that titleset, in order. In fact, it would be only by pure chance or very careful design that any chapter apart from chapter one would align like that.
In the example you have given, you have two titlesets, each with one vob file. Each of these vobs could theoretically have multiple tracks in them (you can have multiple titles in a single titleset)Read my blog here.
As usually every Vob_0a_01, Vob_0a_02, Vob_0a_03... is exactly 1GB (except the last) the chance that any of these fit to a chapter is near 0
That would destroy the structure of the dvd completely (as a is connected with the titleset, and each titleset requires an own IFO file...)If I wanted to go ahead and change the tracks to chapters can I go ahead and change a to 1 and b to the corressponding chapter number without having any problems?
URGENT: Need to output to ASP DivX w/ Multiple Subs, Audio Tracks, Chapters
By Jeet in forum Authoring (DVD)Replies: 0Last Post: 7th Oct 2010, 16:14 -
Video with L/R tracks to DVD with 2 channel audio tracks
By Downloader in forum Authoring (DVD)Replies: 2Last Post: 22nd Aug 2010, 01:56 -
Issues putting tracks and chapters together
By Smack2k in forum Authoring (VCD/SVCD)Replies: 9Last Post: 11th Nov 2009, 13:58 -
TMPGEnc AW 4: just 1 menu for chapters in different tracks
By reini in forum Authoring (DVD)Replies: 4Last Post: 25th Mar 2009, 05:17 -
Automating DVD to Divx 6 With All Subtitles, Audio Tracks, Chapters
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 20th Jan 2008, 17:33
