I am experiencing a problem when trying to use my Xvid videos into Adobe Encore DVD.
This is what I did to convert the 640x480 30 FPS video into a format that Encore likes:
However, here is the problems I've run into. Adobe Encore does not like handling video clips of either Xvid or DivX. They import fine, but when trying to burn a DVD containing either Xvid or DivX video, I get an "Abnormal termination" error or some damn thing.What I did was load my 640x480 video files into TEMPGEnc 3.0 Xpress. In the Filter dialog, I changed the Image Position in the Resize area from Full Screen to Center. Then in the Set Output dialog, I changed the screen size to 720x480 and the framerate to 29.97 FPS. This will add some small black borders to the left and right of your video so that the video is now 720x480 but did not stretch the video disproportionately or crop some of the frame off.
Using TEMPGEnc, I've tried the following options:
Converting to MPEG2 DVD format leaves a bunch of "motion lines" for lack of a better description that are really annoying. I don't know where these lines came from or how to get rid of them. They almost look like interlace lines.
Converting to Windows Media Player 9 format, or any other format/compression that Encore seems to be able to play, does take away some of the image quality.
So I am stuck, if anyone has any idea how to get around this, I would definately like to know.
what options? i don't see them. I have converted several divx and never seen any motions lines.
You can also try mainconcept mpeg encoder, canopus procoder basic.
Adobe Encore DVD Question...
By sdsumike619 in forum Authoring (DVD)Replies: 10Last Post: 26th Aug 2011, 06:46 -
Adobe Encore DVD and subtitles ...
By Liru in forum Authoring (DVD)Replies: 17Last Post: 14th Oct 2010, 17:05 -
Problem importing Russian subtitles into Adobe Encore
By adanepst1 in forum SubtitleReplies: 2Last Post: 29th Jan 2009, 14:12 -
Problem in Adobe Encore DVD
By zombie_chan in forum Authoring (DVD)Replies: 10Last Post: 24th Apr 2008, 01:09 -
Adobe Encore 2.0 DVD Menu
By ozab in forum Authoring (DVD)Replies: 0Last Post: 13th Aug 2007, 17:03
