When I go into the Advanced Encoding Options in MovieFactory, I can choose Aspect Ratios of 4:1 and 16:9. There is another option of 2.1:1 which is grayed out.
The AVI i'm converting is of format 2.1:1. Is there any way to have it as a selectable option? (or make a custom aspect ratio)
I'm using MovieFactory 2 se
PS. For anyone that doesn't know how to get the advanced settings available in MF2, please read here: https://www.videohelp.com/forum/archive/t160090.html
Thanks for any help
I can't see the use of such an AR. The DVD spec allows for 2 aspect ratios - 4:3 and 16:9. Widescreen televisions are 16:9. Nothing would recognise 2.1:1
If your footage is 2.20:1 or 2.35:1, it should be encoded as 16:9, which would leave a small portion of black top and bottom, even on a widescreen TV.Read my blog here.
moviefactory 6 plus problems
By steenuil in forum ComputerReplies: 0Last Post: 3rd Feb 2010, 06:35 -
dvd moviefactory 5
By bigz704 in forum Newbie / General discussionsReplies: 0Last Post: 24th Sep 2009, 14:54 -
Ulead Moviefactory
By acw in forum Newbie / General discussionsReplies: 10Last Post: 24th May 2009, 00:51 -
DVD MovieFactory 6
By Mike99 in forum Authoring (DVD)Replies: 2Last Post: 24th Nov 2008, 05:14 -
DVD MovieFactory 6 Plus
By ozab in forum Authoring (DVD)Replies: 5Last Post: 20th Aug 2007, 16:48
