Hi all,
I hope I am posting in the right section.
I recently have had problems with burning my DVDs, I own a Freecom Classic DVD+/RW Double Layer DVD recorder, and so far I have burnt about 300 DVDs.
I always use Bulkpaq x4 DVDs, and I use nero to copy my DVDs, I dont think Nero is the problem because the same problem happens when I use another burning program.
My Nero Log file is below.
I hope someone can help me out![]()
Peter
Home
1A23-0009-4030-1934-8216-0060
1A25-4706-7030-1366-1263-4647
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.68, size=160016 bytes, created 28/07/2004 16:51:12
Nero version: 6.6.0.0 (Nero Express)
Recorder: <FREECOM_ DVD+/-RW8B9> Version: 2.44 - HA 2 TA 0 - 6.6.0.0
Adapter driver: <> HA 2
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <LITE-ON DVD SOHD-167T >Version: 9S14 - HA 1 TA 0 - 6.6.0.0
Adapter driver: <atapi> HA 1
=== Scsi-Device-Map ===
DiskPeripheral : Maxtor 6Y080L0 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : LITE-ON DVD SOHD-167T atapi Port 1 ID 0 DMA: On
CdRomPeripheral : HL-DT-ST CD-RW GCE-8481B atapi Port 1 ID 1 DMA: On
=== CDRom-Device-Map ===
LITE-ON DVD SOHD-167T D: CDRom0
HL-DT-ST CD-RW GCE-8481B E: CDRom1
FREECOM_ DVD+/-RW8B9 F: CDRom2
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 509MB (522224kB)
Free physical memory: 225MB (231256kB)
Memory in use : 55 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
12.10.2004
DVD-Copy on the fly
20:55:31 #1 SCSI -1065 File Cdrdrv.cpp, Line 1175
SCSI Exec, HA 2, TA 0, LUN 0, buffer 0x03676000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x20
Sense Qual: 0x00
CDB Data: 0xFA 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x06 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x20 0x00
20:55:31 #2 Text 0 File Reader.cpp, Line 127
Reader running
20:55:31 #3 Text 0 File Writer.cpp, Line 122
Writer FREECOM_ DVD+/-RW8B9 running
20:55:31 #4 Text 0 File DVDCopy.cpp, Line 267
DVD Track-Information from source disc
S01 T01 Con 0x04 Start 0 Len 2298496 (gap 0) Blank 0 Res 0 Dmg 0 Mode TRM_DATA_MODE1 (0)
20:55:31 #5 Text 0 File DVDCopy.cpp, Line 370
Max -1 tracks of 1 allowed to copy
1: 0 - 2298496 = 2298496, TRM_DATA_MODE1, block size 2048, read opt 0 (no read options)
20:55:31 #6 Text 0 File Burncd.cpp, Line 3119
Turn on Disc-at-once, using DVD media
20:55:32 #7 Text 0 File DlgWaitCD.cpp, Line 256
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2298495 (510:46.45, 4489MB)
20:55:32 #8 Text 0 File DlgWaitCD.cpp, Line 268
Write in overburning mode: NO (enabled: CD)
20:55:32 #9 Text 0 File DlgWaitCD.cpp, Line 2310
Recorder: FREECOM_ DVD+/-RW8B9, Media type: DVD-R
Disc Manufacturer: INFOSM - ART01
Disc Application Code: 64, Disc Physical Code: 193
20:55:32 #10 Text 0 File DlgWaitCD.cpp, Line 430
>>> Protocol of DlgWaitCD activities: <<<
20:55:32 #11 Text 0 File ThreadedTransferInterface.cpp, Line 844
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (1 - Data (mode 1))
2 indices, index0 (150) not provided
original disc pos #0 + 2298496 (2298496) = #2298496/510:46.46
not relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2298496 blocks [FREECOM_ DVD+/-RW8B9]
20:55:32 #12 Text 0 File ThreadedTransferInterface.cpp, Line 1045
Prepare recorder [FREECOM_ DVD+/-RW8B9] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x40; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4707319808, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
0 | lead-in | 0 | 0x00 | 0x41
0 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
2298496 | lead-out | 1 | 0x00 | 0x41
20:55:32 #13 Phase 36 File dlgbrnst.cpp, Line 1861
Burn process started at 4x (5,540 KB/s)
20:55:32 #14 Text 0 File ThreadedTransferInterface.cpp, Line 2471
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
20:55:32 #15 Text 0 File dlgbrnst.cpp, Line 1719
Set remaining time: 14:14,744 (854744ms) -> OK
20:55:32 #16 Text 0 File DVDR.cpp, Line 1955
Recording mode: Sequential Recording Mode
20:55:32 #17 Text 0 File Mmc.cpp, Line 20542
Set BUFE: Buffer underrun protection -> ON
20:55:32 #18 Text 0 File DVDR.cpp, Line 2096
Start write address at LBA 0
DVD high compatibility mode: Yes
20:55:32 #19 Text 0 File Cdrdrv.cpp, Line 8259
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26127F h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Start sector number of the current Border-Out: 2FE10 h
Start sector number of the next Border-In: 2FFA0 h
Media Specific [16..63]:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ................
20:55:32 #20 SCSI -1065 File Cdrdrv.cpp, Line 1175
SCSI Exec, HA 2, TA 0, LUN 0, buffer 0x0ADA4000
Sense Code: 0x20
Sense Qual: 0x00
20:55:52 #21 Text 0 File Cdrdrv.cpp, Line 1281
20:55:52.328 - FREECOM_ DVD+/-RW8B9\H2 T0 : Queue again later
21:04:55 #22 SCSI -1128 File Cdrdrv.cpp, Line 1429
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x07FF4000
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x11
Sense Qual: 0x06
CDB Data: 0x28 0x00 0x00 0x15 0xBC 0xA0 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x11 0x06
21:04:55 #23 TRANSFER -25 File Reader.cpp, Line 380
Error reading data
21:05:05 #24 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
21:05:05 #25 Text 0 File DVDR.cpp, Line 2338
EndDAO: Last written address was 1424543
21:10:24 #26 SCSI -1065 File Cdrdrv.cpp, Line 1175
Sense Code: 0x20
Sense Qual: 0x00
21:10:24 #27 Text 0 File dlgbrnst.cpp, Line 1719
Set remaining time: 0:00,000 (0ms) -> OK
21:10:24 #28 Text 0 File dlgbrnst.cpp, Line 1719
21:10:24 #29 Phase 38 File dlgbrnst.cpp, Line 1861
Burn process failed at 4x (5,540 KB/s)
Existing drivers:
File 'Drivers\atapi.sys': Ver=5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), size=95360 bytes, created 03/08/2004 22:59:44 (Adapter driver for src)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Many thanks
FinalHolmes
Results 1 to 1 of 1
(1) Burn failed !!
By skinney6 in forum DVD RippingReplies: 13Last Post: 4th Feb 2010, 18:01 -
DVDfab failed initializing burn engine
By etlund99 in forum ComputerReplies: 0Last Post: 29th Jul 2009, 13:19 -
Does SVCD2DVD process and burn HD quality DVD from HD .ts file?
By jeemak in forum Authoring (VCD/SVCD)Replies: 1Last Post: 21st Nov 2008, 22:03 -
New DVD writer... Burn process failed at 2x (2,770 KB/s)
By planetx in forum DVD & Blu-ray WritersReplies: 8Last Post: 8th Feb 2008, 15:40 -
Encoding Failed
By hananke in forum ffmpegX general discussionReplies: 5Last Post: 11th Jul 2007, 06:04
