Hello,
I wish to speed up by 2 an mpeg1/mpeg2 movie file for a presentation.
Any IDeas on method/software etc?
Sorry if in wrong forum.
Regards
Joker2![]()
Yeah Baby!
Are you talking using a computer or a settop player?
If computer: Use ReStream to change the flag that says the Frame Rate and save as a new file. No re-encodes so will look just as good. Should play at the new speed (probably should be a valid MPEG speed, though).
If settop, you probably have to use a Video Editor (Premiere, Vegas, etc) or VirtualDub or AfterEffects and adjust the speed/add speed effect, and then re-encode with the new speed. This WILL lose quality.
(Wait a minute--If you don't use a valid MPEG/VCD/DVD speed after re-encoding, you probably can't author it for settop use.)
My preference then would be to use a Motion Effect in AfterEffects, which will give the faster speed (and probably less playtime), but will still play out at the standard FPS.
HTH,
Scott -
Set top player.
Basically I have a file I want to speed up for comedy value and add music to it.
Thanks for your reply.Yeah Baby! -
Vegas does this very well ...
after effects also and a lot of other high end software ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Sony Vegas: Any way to undo clip speed adjustment?
By duderdude2 in forum EditingReplies: 2Last Post: 15th Feb 2010, 21:03 -
Fixing Speed of Video (originally film)
By mark23 in forum RestorationReplies: 1Last Post: 2nd Jan 2010, 13:59 -
Change speed on a clip in Premiere?
By FredAstair in forum EditingReplies: 5Last Post: 18th Jan 2009, 13:08 -
How edit a clip to play @ 1/2 speed (slow motion) in Vegas 8 plt.
By Jensen in forum EditingReplies: 7Last Post: 12th Feb 2008, 12:23 -
How to add pulldown flags to a clip of mixed film/video?
By Mizkreant in forum Video ConversionReplies: 6Last Post: 14th Aug 2007, 06:05
