    May 2002
    Normal, IL
    Last year I found a guide someplace which explained how to setup a software video player on your pc that made dvd video look incredible. I think he used videolan, upconverted the resloution and applied some filters and whatnot. Now that I have an HDTV, I would like to hook it up to my PC using my Video cards DVI. I recall some of the comparison screenshots were of YODA from EP1 or EP2. Does anyone have or know where I might find this guide. I have been searching google for days. Thanks
    May 2004
    Hello homerj,
    This might be it (or similar to what you are loking for if I understand what you are asking): http://www.kevinrose.com/index.php/weblog/comments/creating_a_pc_dvd_jukebox/
    It's from Kevin Rose's blog. He is the host of the G4TechTV show The Screensavers. Hope this helps!
    May 2002
    Normal, IL
    Thanks video_guy, but that was not what I was looking for. Fortunatly, I found the guide the other day. If anyone might be interested, here is the link
    http://htpcnews.com/main.php?id=ffdshowdvd_1
