After removing some extras i did not want from an original dvd i see that even if everything on the DVD is fine, the DVD starts with the trailer of the movie and not with the main menu.
I have to wait until the trailer finish, or press the Main Menu button to go to the main menu of the dvd.
I have used DVDSplitter and i hae checked the DVD with the WINDVD with the option "DVD From Folder" to test it.
Do you know how can i fix this sequence?
Does the original DVD start from the menu? - some don't.
You could also try vob blanker, it doesn't alter anthing except for what you don't want. -
Did you remove the trailer? Do you mean that you thought you removed it but it's still playing? As jetfan said, if the original DVD started with the trailer (instead of the main menu), and if you didn't blank that trailer, then your modified DVD will also start with it!After removing some extras i did not want from an original dvd i see that even if everything on the DVD is fine, the DVD starts with the trailer of the movie and not with the main menu.
If you don't want the trailer, you have to blank it. You can use titlesetblanker, or pgcedit or vobblanker for that.
Jeanl -
TittlesetBlanker removes only the whole tittleset.
VobBlanker removes titles and not tittlesets.
This is the reason i am using DVDStripper - because it can removes tittles, tittleset and also remove stuff from inside any VTS.
Now, what about my problem....
No, i don't want blank the trailer of the movie. I want it on the DVD.
But, for unknown reasons, when i tested what i have done with WinDvd, the starting point of the DVD was the trailer, and not the main menu of the movie.
Because i got tired with that problem, i decided to burn it as it is. When i checked the DVD on my JVC XV-N55 DVD Player, the starting point was correctly the main menu of the movie.
Unfortunately, in spite of my view with WinDVD, i can press the buttons that i have removed with MenuModder. (In WinDVD when i pressed such buttons, the DVD just did...nothing - as i wanted).
On my DVD player now, when i press such buttons, something strange happens....the menu arrow stucks on that button and can not move to the other buttons. I have to change the track of the DVD manually, and go back to the main menu to start from the begin....
Yes i know....
..... strange things....
I do not know if someone can help in that situation.... -
It is true that titlesetblanker removes whole titlesets, but vobblanker can do everything: whole titlesets, titles, even parts of titles (cells and even parts of cells), so it's extremely powerful.TittlesetBlanker removes only the whole tittleset.
Now, I have no idea what went wrong with your DVD, I don't know what algorithm DVDSplitter uses to remove titles or parts of titles. It sounds to me like you have something slightly non compliant on the DVD you created, hence the various results.
Vobblanker usually creates compliant DVDs although I've heard one user report a problem with a blanked DVD (see this thread: http://forum.doom9.org/showthread.php?s=&threadid=83701)
You might want to give vobblanker a shot, maybe that will solve your problem...
Jeanl
need some help with sequence maker
By beta72 in forum EditingReplies: 1Last Post: 17th Oct 2011, 20:44 -
best possible sequence settings
By pjcom in forum EditingReplies: 15Last Post: 26th May 2010, 10:12 -
Recomended sequence.
By Tafflad in forum RestorationReplies: 0Last Post: 19th May 2010, 15:31 -
BMP to AVI sequence
By max_e_mum in forum EditingReplies: 6Last Post: 17th Aug 2009, 05:57 -
VIDEO TS sequence
By red lion in forum EditingReplies: 1Last Post: 25th Jun 2007, 19:15
