I am having a problem with converting a SVCD to DVD. First I use Isobuster to convert it to a mpg then I use virtualDub to convert to a avi (compressing with divx). Last I use tmpgenc to convert to dvd and autor it using tmpgenc. The Main problem that I am having is that on the SVCD disk it is show widescreen 576x260 but when I convert it it shows at 480x576. Is their something I can do in tmpgenc. I have tried changing the Video arrange Method to Full screen (keep aspect ratio) but it does not work. thanks
Hello,
Why don't you convert to mpg only???? Dvd standard is mpeg2. That may be part of your problem.
Also, use keep aspect ratio should be the best bet.
Originally Posted by kman0199
In order to convert to DVD compliant format, use it direct in TmpGenc (or frameserv it from dvd2avi) and set the resolution to 352*576 (or 720*576, though I reccomend the lower res in this case). Use full screen keep aspect ratio and set the aspect ratio on the video tab of the settings dialog as 16:9. This should work fine.
Problem converting H264(mkv), keeps crashing while converting.
By weedelf in forum Video ConversionReplies: 4Last Post: 9th Apr 2009, 23:56 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 11:58 -
will changing bin files to dvd improve sound quality?
By motleycool in forum Newbie / General discussionsReplies: 1Last Post: 15th Sep 2007, 04:40 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 10:36 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 21:26
