i got a great deal on some 1X - compusa brand dvd-r........
i burned dvds and they burn fine and playback fine.....the only downside is that they are 1X.......now...is there a problem if they are 1X....am i getting a quality dvd minus the speed or just crap all the way around.......
1x PRINCO
www.nomorecoasters.comWant my help? Ask here! (not via PM!)
Princo brand disc's seem to get bashed all the time, myself, that is the brand I have used from the start and the speed 1x
Most of the time it is not important to me how fast the burning process is, therefore I do not see the advantage of using higher priced media if my results are satisfacory with the cheaper (Princo -r 1x)
Just bought 600 at $20/100 a few weeks back, gave them to my grown children so they would not be concerned about the cost of learning how to burn me some video's of grandkids
Using ADS usb InstantDvd-2 with the latest capwiz ver 3.5 (cap program) that has a true DTD (direct to disc) option I have not had a problem using Princo -r 1x media at all
To me, the bottom line is, do they work well for YOU.
They do for me, so I keep buying them
Very good information site above, if you did not go read it, do so. -
I got suckered into buying some of their DVD-R's. 50 or was it 100 for $20.00?
I thought they were 4x, but turned out to be on 2x's. So for so good. I just use them for backing up old data.
haali media - use custom media type for h.264
By adom in forum Video ConversionReplies: 0Last Post: 15th Mar 2011, 06:07 -
AccountKiller
By rcvalle in forum MediaReplies: 3Last Post: 13th Dec 2010, 22:05 -
How To Convert DVD Media Made From VHS Media For Sharing Online
By BlazingSpeed in forum Video Streaming DownloadingReplies: 0Last Post: 11th Dec 2010, 14:20 -
No Sound Coming From Media Player or Online Media Players
By Teac23 in forum AudioReplies: 4Last Post: 11th Jul 2010, 07:52 -
DMR-EZ27 records on rewriteable media, but gives U61 error on other media!
By dr-rjp in forum DVD & Blu-ray RecordersReplies: 2Last Post: 11th Jun 2008, 18:58
