i have a nVidia card....and it has a S-video out feature.......i am expirancing a couple of problems with it....
1) if i want to use the S-video feature i have to unplug the moniter from the back and then i the s-video is enabled.....
is there a way that i can just turn on s-Video feature
2) when i do enable the s-video and have it working...on my TV it is not a clear image....IT IS NOT THE SAME QUALITY of picture as MY MONITER......it has a "FOGGY" picture to it........is there a way to fix that
3) is ther a way that i can have the s-video and the moniter on at the same time and have then enabled at all times.........
thanks ahead
Learn all about Nview; wonderful step by step instructions with illustrations:
http://download.nvidia.com/Windows/61.76/ForceWare_Release_60_Graphics_Display_Propert...sers_Guide.pdf
edit:
TV resolution is considerably less than a monitor, possible causing the "foggy" image quality. In my experiences, TV is OK if your using it to watch movies from your computer, but terrible for any other use.Usually long gone and forgotten -
(anyone know how to delete a redundant post?)
thanks for the information.....got the TV to work the whole time with the regular screen........now for the fogging.......... yes the quality of the picture is considerably less..... is there a special nVidia compatable DVD/media player that will work better with my TV........is there any other setting that i can change to make it considerably better..............
thanks again
No need for nvidia drivers?
By A Traveller in forum LinuxReplies: 27Last Post: 7th Dec 2011, 12:06 -
Nvidia 9400gt hdmi
By sanosuke in forum DVB / IPTVReplies: 2Last Post: 2nd Apr 2011, 04:14 -
Nvidia Physx
By Jomapil in forum ComputerReplies: 0Last Post: 30th Nov 2009, 05:32 -
nVidia fx5200 new drivers
By maansingh169 in forum Media Center PC / MediaCentersReplies: 1Last Post: 20th Aug 2008, 22:16 -
TV out using 7900 GS (nvidia)
By SignedupGuest in forum Newbie / General discussionsReplies: 7Last Post: 29th Jul 2007, 08:46
