Is there better programs then Tmpgenc and Cucusoft to convert AVI's those are the two ive tried.. tmpenc gives me errors and cucusoft worstens the quality of the sound/video... is there any other program that i could use.
Results 1 to 13 of 13
If TMPGEnc gives you errors, the AVI is probably damaged in some way. For other options, take a look under Encoders in the Tools section.
/Mats -
My prefrence is MainConcept encoder - mainly for speed,
but as mats said your file is most likly damaged in some way, you should scan it for errors using vdub-mp3-freeze then look at the badframes.log file and cut out the bad parts (starting with the last first) -
Woops i didn't explain it too well... it doesn't give an error... the finished copy is all choppy
Originally Posted by Snoop69
What setting for "Motion Search Estimate"?
How about the source AVIs? Use AVICodec to get info on them and post here - it might be that they're not a good quality source.
Post more info (now and always)...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Originally Posted by Snoop69"Art is making something out of nothing and selling it." - Frank Zappa
Hi Snoop69,
When you're encoding to MPEG with TMPGEnc:
1. Are you encoding for VCD, SVCD or DVD?
2. If DVD, what resolution are you using? You're not using 720 x 480 / 576 (NTSC / PAL) by any chance are you...?There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Originally Posted by ZippyP.
and i tried that but it still turns out choppy -
...but VCD what? NTSC or PAL?
/Mats -
Frameserve with virtualdub your avi file to TMPGenc.
Use the PAL VCD template on TMPGencLa Linea by Osvaldo Cavandoli
Problems converting AVI to vcd format using TMPGenc 2.5 Plus
By peterock in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 15:34 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 20:27 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 23:23 -
Converting vfr-avi to cfr-avi that produced error in picture.
By Jo The Veteran in forum Video ConversionReplies: 27Last Post: 1st Aug 2007, 23:41
