    May 2004
    Harpenden UK
    Hi Chris,
    Can you advise please. Recently reinstalled my system (Win XP Pro) reinstalled SVCD2DVD and followed your instructions to edit the 'NoEXECUTE=OptIn' command and SVCD2DVD installed ok. Tested it and it ran fine. Now today I try to run the program and I get as far as the splash screen and then...nothing, nichts, nada It doesn't start up, it is a registered version and the latest version too, any suggestions please, while I await your reply I'll try a reinstall
    Best
    Zolly
    Zolly Littlechild
    ICQ 4232440
    SMS : ask me
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    There may have been a change to your system. If you double click on the "SVCD2DVD demo.exe"file in the SVCD2DVD folder you can redo the registration process. This should solve the problem.
