Hey all. I am tired of burning movies to DVDs to play in my DVP642 only to find that they will not play once in there. I tried downloading Gspot and it does not report if a Xvid version for a file (at least I cannot find it). It only seems to report if it is an Xvid, Divx5, etc. As most people know (who own the DVP642 anyway) that right now the player will not play anything encoded as an Xvid version 1.0 or greater. Any other tool out there that will do this?
Hi,
One way to burn movies so they work in a dvd player is to burn them with nero with vcd, if your dvd player is able to see VCD's.
If you want to change the codec virtualdub will do that. -
thebunk,Originally Posted by thebunk
I don't know what you're talking about. I just bought this player, I do all my encodes with XviD (now using 1.0.2), and it plays everyting perfectly. It plays all DivX files. It even plays DivX 3.11 okay.
What it will NOT do is play files encoded with global motion compensation (GMC) or Quarter pixel (OPEL). Neither will most other players right now. Make sure you have the latest version of GSpot. There are icons at the top right (just underneath the line telling you if the codecs are installed) which light up if the file has 'QPEL' or 'GMC.' If those boxes are not lit up, your file should play. There are also icons indicating use of B-VOPs and N-VOPs. I think there may be some restrictions on the number of those, but so far every file I've played with B-VOP and N-VOP has played fine.
Just burn as plain data in Nero or any other burning application. It doesn't matter if you burn them on a DVD or a CD; they should play fine. But for DVD, make sure you do not burn as a DVD; just burn your discs as data on the DVD.
One more thing: My player came with the latest firmware. You may want to check for an **upgrade.**
-abs"The purpose of art is not the release of a momentary ejection of adrenaline but rather the gradual, lifelong construction of a state of wonder and serenity." --Glenn Gould -
Just use this http://johnnys.nailed.org/avicheck.zip
Anything with QPEL or GMC listed in the video section will NOT play on your DVP 642. Everything else has worked fine here so far.
Avisynth and Xvid, which version to use?
By stephens in forum Video ConversionReplies: 6Last Post: 26th Nov 2009, 14:16 -
Does xvid cli (command line version of xvid) actually exist ?
By vhelp in forum ProgrammingReplies: 10Last Post: 29th Oct 2009, 15:18 -
xvid 1.357 final? there's a such a NEW version?
By puzzledman in forum Video ConversionReplies: 8Last Post: 3rd Oct 2008, 05:24 -
Converting x264 to xvid for dvp642 standalone player
By ch4757 in forum Video ConversionReplies: 19Last Post: 23rd Jul 2007, 13:44 -
DVP642, unable to read version
By scarpezio in forum DVD & Blu-ray PlayersReplies: 3Last Post: 23rd Jul 2007, 12:32
