Please Help me transform a film to this format form the
divx format.
Explain it to me simple please, with links to programs.
Thanks.
Divx is basically Mpeg4 (*.avi) There are a few differing versions available .
eg: 3.11, 4.11 , angel potion
Note: angel potion is a hack , i use it , but virtual dub has issues.
How To : Get appropite Divx codec.
load file into Virtual Dub.
edit as required
frame serve to TMPEGEnc
make Mpeg1 (vcd 1150,224)
Goto the virtual dub web page for more info on frameserving
All this is pointless since the mpeg4 file will most likly have a lower video AND audio bitrate than the VCD standard.
Trying to make something outta nothing ...... again -
In order to convert DIVx movies to VCD with TMPGenc, do the following:
1. With Virtual Dubbing in full processing mode extract audio from the movie (File->Save WAV)
2. Rename the audio file from WAV to MP3 and use it as the audio source with TMPGEnc.
3. Of course, the video source will be the actual DIVx movie.
4. Load the VCD PAL/NTSC template and hit encode.
Note:
This will only work with DIVx codecs version 3.11 installed.
Convert A DivX with AC3 To VCD
By Stinky in forum User guidesReplies: 43Last Post: 23rd Jul 2011, 03:55 -
VCD to Divx conversion
By silverarrow in forum MacReplies: 14Last Post: 18th Feb 2010, 08:25 -
Divx to VCD
By d_unbeliever in forum Authoring (VCD/SVCD)Replies: 16Last Post: 30th Apr 2009, 00:19 -
VCD to DIVX Conversion
By DarkPhoenix77 in forum MacReplies: 2Last Post: 16th Mar 2009, 12:28 -
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 17:01
