  1. I can encode a ripped VIDEO_TS folder with Handbrake no worries. The video and audio both come out OK. However, I wish to use ffmpegX so that I can have more control over the encoding process.
    I have used the settings below on exactly the same VIDEO_TS folder, and the picture is very good. However, there is no audio at all. What intrigues me is that it appears that ffmpegX can't actually find the audio to encode. When I preview the settings there is no sound, and the log file says "MPEG: No audio stream found -> no sound."
    If anyone could tell me what I'm doing wrong regarding the audio I'd be grateful. I've tried this method on two other DVDs, no change.
    Also, if anyone has any suggestions on a better config to create a 700MB file that will be playable for most people, I'd love to hear them. All that I have done on the video page is switch the aspect to 16:9 and pressed 'auto', returning the video size and bitrate that you see. Should I use another codec, even?
    Thanks.
    Screens:
    Log:
    Encoding started on Tue Sep 21 23:23:34 EST 2004
    MEncoder dev-CVS-040904-19:44-3.3 (C) 2000-2004 MPlayer Team
    AltiVec found
    CPU: PowerPC
    Reading /Users/xxxxxxx/.mplayer/codecs.conf: Reading /usr/local/etc/mplayer/codecs.conf: Using built-in default codecs.conf.
    libdvdread: Couldn't find device name.
    Font /usr/local/share/mplayer/font/font.desc loaded successfully! (206 chars)
    Reading disc structure, please wait...
    There are 14 titles on this DVD.
    There are 16 chapters in this DVD title.
    There are 1 angles in this DVD title.
    DVD successfully opened.
    success: format: 0  data: 0x0 - 0x73f5000
    MPEG-PS file format detected.
    Too many video packets in the buffer: (4096 in 8272974 bytes).
    Maybe you are playing a non-interleaved stream/file or the codec failed?
    For AVI files, try to force non-interleaved mode with the -ni option.
    VIDEO:  MPEG2  720x576  (aspect 3)  25.000 fps  8500.0 kbps (1062.5 kbyte/s)
    [V] filefmt:2  fourcc:0x10000002  size:720x576  fps:25.00  ftime:=0.0400
    xvid: using library version 1.0.1 (build xvid-1.0.1)
    Opening video filter: [expand osd=1]
    Expand: -1 x -1, -1 ; -1  (-1=autodetect) osd: 1
    Opening video filter: [scale w=512 h=288]
    Opening video filter: [crop w=718 h=554 x=2 y=10]
    Crop: 718 x 554, 2 ; 10
    Opening video filter: [pp=md]
    Opening video filter: [pp=0x77]
    Opening video decoder: [mpegpes] MPEG 1/2 Video passthrough
    The selected video_out device is incompatible with this codec.
    VDec: vo config request - 720 x 576 (preferred csp: Mpeg PES)
    [PP] Using external postprocessing filter, max q = 6.
    Could not find matching colorspace - retrying with -vf scale...
    Opening video filter: [scale]
    VDecoder init failed :(
    Opening video decoder: [libmpeg2] MPEG 1/2 Video decoder libmpeg2-v0.4.0b
    Selected video codec: [mpeg12] vfm:libmpeg2 (MPEG 1 or 2 (libmpeg2))
    Writing AVI header...
    ed, not writing vprp header.
    VDec: vo config request - 720 x 576 (preferred csp: Planar YV12)
    VDec: using Planar YV12 as output csp (no 0)
    Movie-Aspect is 1.78:1 - prescaling to correct movie aspect.
    xvid: bitrate setting is ignored during first pass
    SwScaler: reducing / aligning filtersize 4 -> 4
    SwScaler: reducing / aligning filtersize 5 -> 4
    SwScaler: BILINEAR scaler, from Planar YV12 to Planar YV12 using AltiVec
    videocodec: XviD (512x288 fourcc=44495658 [DIVX])
    xvid: 2Pass Rate Control -- 1st pass
    1 duplicate frame(s)!
  2. Apparently mencoder failed to recognize the audio track. Try using 0SEx first to extract as a single VOB file, instead of a VIDEO_TS structure.
    -> here
    sometimes switching audio track from 0 to 1 etc. can help
  4. major - thanks, I ripped it into a single VOB first and it was fine.
    ykz - I tried that and no love. Looks like it's the 0SEx method for moi.
