Hello,
Is anyone here very familiar with the MPEG4 Modifier program from Moitah.net? It has been recommended by some here to use to make Xvids with non-square pixels and packed bitstreams compatible with the Philips 642 DVD player.
It basically changes custom pixel shape ratios to square pixels and packed bitstreams to unpacked. My file sizes are always smaller after conversion to square pixels or unpacked.
My question and concern is, does this affect the integrity, accuracy or quality of the original file at all? Should I shave the originals because they are more accurate or are the converted files basically identical?
Just want to know if I should back up both the originals and the converted-for-compatibility files or is this truely redundant?
Thanks for any definite answers,
Mike
why shave the originals ? for what purpose?
In case the originals are more accurate. I will have them archived for future conversions if needed.
My question is does MPEG4 Modifier change the file in a way that takes away from the ULTIMATE quality or the original. Like I said the files are a couple of megs SMALLER after conversion. What is lost?
Mike
BTW MPEG4 Modifier does what it does wonderfully and very quickly! It is a great program if you are having issues with some XVIDs on the Phillips 642 or Yamada players.
Delete Original file with MPEG4 Modifier Commandline?
By rvman in forum Video ConversionReplies: 6Last Post: 28th Jul 2009, 17:55 -
mpeg4 modifier application error
By fundaris in forum Newbie / General discussionsReplies: 3Last Post: 23rd Feb 2008, 07:59 -
Help with MPEG Modifier... Packed Bitstream...
By GangstaRap in forum Newbie / General discussionsReplies: 0Last Post: 24th Dec 2007, 12:14 -
MPEG4 Modifier and GSpot for Mac?
By tzikeh in forum DVD & Blu-ray PlayersReplies: 1Last Post: 15th Nov 2007, 23:06 -
Getting DVDs to MPEG4-SP or MPEG4-AVC
By WoWchamp in forum DVD RippingReplies: 7Last Post: 30th Oct 2007, 23:47
