I have just bought a Samsung 542A burner. Tried backing up movies on Sony 4x DVD-r and Princo 4x. While burning on Princo the burn process stops at 89%. It burns successfully on the Sonys but when playing the movie on a DVD player the starting of the movie is of great quality but it starts skipping and stopping as the movie goes on till it is unplayable. I have used DVD Fab, DVD shrink, DVD Decryptor for ripping and burning but the results are all the same. I have also used Nero Burning Rom 6 for burning.
I have tried ripping and burning atleast 6 diffrent movies all with the same result (as I did not wanna waste my sony disks) The previews of the movies in DVD shrink is excellent. Only after it is burnt the problem crops up. I have tried my Pioneer 16x DVD Rom also for ripping.
Should I use another brands of DVDs or is there something wrong with my recorder.
Hello nuttypro.
Some options:
- burn at a lower speed.
- lower DVD Shrink target size to 4300MB, so as not to write to/read from the discs outer-edge.
"Edit >> Preferences >> Target Size >> Custom >> 4300MB"
- use better media. -
buy some 4x prodisc from www.rima.com
much better quality than princo discs.
your problems sound like bad media to me.
Problems backing up DL dvds using DVD Shrink and ImgBurn
By ManuBumb in forum Newbie / General discussionsReplies: 9Last Post: 7th Apr 2009, 21:35 -
Backing up my dvds and the chapters are scrambled?
By Ronja in forum Newbie / General discussionsReplies: 1Last Post: 5th Oct 2008, 16:22 -
Weird issue backing up DVDs
By downer in forum DVD RippingReplies: 6Last Post: 26th Aug 2008, 13:40 -
Backing up RedBox DVDs?
By punkhop in forum Authoring (DVD)Replies: 1Last Post: 29th Aug 2007, 20:28 -
'backing up' dvds
By nobbyiscool in forum Newbie / General discussionsReplies: 3Last Post: 13th Aug 2007, 20:25
