  1. Hi
    I just made a vcd using dvd2svcd, but when i play the picture is all pixelised when there is action in the movie. i was windering if you guyz can help me out which data rate and etc i could use to get rid of this.
    the movie is about 3 hrs. [/i]
  2. Member daamon's Avatar
    Melbourne, Oz
    Hi nirbhayn,
    VCD is fixed at 1150 kbps bitrate and, for faster moving scenes, this could well cause pixelation.
    From what I know about VCD, because the bitrate is fixed, I'd say that you're just gonna have to accept - though I'm happy to be proven wrong...
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  3. wat if i use svcd and set the data rate to 2 pass vbr
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Could help a little, but I'd suggest doing 2 pass SVCD (or CVD, depending on source resolution) with close to 2000 kbps average bit rate.
    /Mats
