i am trying to make a backup of a dvd, and have ended up with a folder on my desktop, with the following files in it:
11 vob files
5 ifo files
5 bup files
1 std file
they are all together in my backup folder, when i try to use tmpgenc dvd author to burn these to a disc, it says it cannot write as incorrect dvd structure - folders missing.
im guessing i need to put these files into folder before burning but what do i name these folders? and the files listed above - which files go into which folder?
help appreciated
Hi kazz0817,
Off the top of my head, I'd say you need to put them all in a VIDEO_TS (must be in CAPS) folder.
You don't need to use TDA, just put all the files in a VIDEO_TS folder on your HDD and burn that (along with an empty AUDIO_TS folder) to your DVD.
That should do the trick...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
DVD structure
By gbabione in forum DVD RippingReplies: 6Last Post: 19th May 2010, 23:41 -
HD DVD Disk Structure?
By wulf109 in forum Blu-ray RippingReplies: 4Last Post: 7th Jan 2009, 00:58 -
Problem making backup of The Dark Knight Region 2 DVD
By soneman in forum DVD RippingReplies: 4Last Post: 14th Dec 2008, 16:48 -
Svcd structure
By nichok72 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 19th Aug 2008, 17:03 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 13:03
