Looking to trasnfer some VHS to DVD. My parameters:
-audio must be uncompressed PCM. can't deviate from this.
-want to capture as mpeg-2 to avoid "massive" file sizes of 20gb
-want an external (hardware) converter as my PC only has 256mb ram
-should be firewire based I suppose.
-budget is less than $400
Have excellent playback device, also Sony Vegas (will this recognize firewire input for capture?) and DVD Architect. So the software is just about covered.
What do you recommend for a hardware converter? I see lots of conflicting opinions in the review section. My friend likes the Pinnacle Studio 9 DV Firewire MovieBox but you can only get PCM audio if you capture AVI (massive file size problem for me). The mpeg-2 capture is ac3 audio![]()
I have the ADS usb InstantDvd-2 device and it will do any analog in whth your choice of audio.
They also have the InstantDvd +dv which also accepts dv input.
Excellent quality but neither have a tuner, pvr or scheduleing
Also have the Compro usb VideoMate Live that has tuner, pvr and schedule. Does not seem to have audio option you want, only choice I see is 48 or 41 . Also of excellent quality
Price range $150/200 USD -
Buy a DVD recorder that does PCM.
Two slightly conflicting requirements there it appears!Originally Posted by NewHomebrew
How about the ADVC-100 with the mainconcept encoder. The ADVC will convert the video to DV (with PCM audio). This is then transferred via firewire to your PC where mainconcept will 'capture' it and convert to mpeg-2 on the fly.
If you have any cash left over after purchasing whatever you decide, why not splash out on a memory upgrade for your PC. Memory is pretty damn cheap these days
Thanks for the suggestions. I will look into all of them, although I don't know if a standalone will give me the kind of control I want over bitrate and the ones I have encountered use ac3 audio.Originally Posted by bugster
I don't like compressed audio. Just my thing. The program for each dvd is less than an hour so the space is available to use both max video and audio bitrate. -
In that case, know that recorders generally have PCM audio at 1-hour mode (the JVC DR-M10S does for sure).
This is probably perfect for what you want.Want my help? Ask here! (not via PM!)
Hardware monitor calibration device
By sdsumike619 in forum Newbie / General discussionsReplies: 1Last Post: 2nd Mar 2011, 12:46 -
Best MPEG-2 Capture Device?
By dorenhagen in forum Capturing and VCRReplies: 101Last Post: 26th Feb 2011, 16:49 -
Hardware MPEG-2 Capture Software ATI Theater 550 Pro
By CaZeek in forum Capturing and VCRReplies: 9Last Post: 22nd Nov 2010, 12:57 -
What is the best format to capture and archive HD DV content.
By nashmarkt in forum Capturing and VCRReplies: 8Last Post: 10th Dec 2009, 14:41 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 05:31
