yes i know sharpee is not a verb
but I got thermal discs for the first time, they were taiyo yuden 8x R- (only .52 each!) I had no idea thermals where plain metalic/silver, basically looks like the other side of the disk
so i know this questiong is dumb, but i just wanted to make sure'
is it safe to write on thermall discs with a soft point sharppee
I am using these disks strictly for backing up my dvd filled hardrives
thanks!
Its safe,ive labeled all my cds and dvds with a sharpie for the last 5 years without any problems yet.Thermals are used for heat induced labels and are safe to write on.
thank you now i am at ease
I am a sharpee addict, nothing new here, Ive owned so many different ones, the ones with the chisel tip are good for those with artistic ability
right now i have a clickable one, the tip goes in and out like a pen, no more caps!
Inkjet -vs- Thermal
By Nator in forum ComputerReplies: 5Last Post: 19th Mar 2012, 08:08 -
Is it safe to sell our free cell-phones? Also, is it safe to BUY?
By siratfus in forum Off topicReplies: 3Last Post: 12th Dec 2009, 16:30 -
Writing on Thermal DVD-r's?
By videobread in forum MediaReplies: 30Last Post: 8th Aug 2009, 13:15 -
Thermal paste...
By kenmo in forum ComputerReplies: 16Last Post: 3rd Apr 2009, 21:08 -
Is it safe to write on DVDR BEFORE burning?
By snowbound in forum Authoring (DVD)Replies: 6Last Post: 23rd Mar 2008, 21:29
