Hello. I have a problem, but I think I fixed it. I want to make sure. So, I just installed a DVD-/+RW as a slave drive and the DVD-ROM as the master. When I turned the comptuer on, it would only detect 1 at a time. I tried changing the order. I put the DVD-/+RW as master and the DVD-ROM as the slave and it seemed to be working. I wanted to try, but I happen to be out of DVD-Rs. Can someone tell me if I will be able to burn DVDs like this?
Thank you,
Sean
Yes you should be able to. My burner would only work when set as MASTER too.Originally Posted by shifted90
CD-ROM vs. DVD-ROM
By Judson in forum MacReplies: 10Last Post: 6th Apr 2012, 09:33 -
mini DVD recorded by SONY DCR-DVD203 unreadable at DVD ROM of PC
By knightatarms in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 31st Dec 2010, 11:02 -
Question about BD-ROM
By II AnDo II in forum DVD & Blu-ray WritersReplies: 3Last Post: 30th Dec 2008, 19:39 -
DVD Rom reads DVD but won't play DVD
By cougaris in forum DVD & Blu-ray PlayersReplies: 2Last Post: 27th Jul 2008, 22:58 -
Question: DVD, CD or ROM DYE LIFE
By mjk4ty in forum MediaReplies: 1Last Post: 10th Feb 2008, 20:18
