Hi all,
I have been using Vegas to edit PAL interlaced DV content and export it
to the same format (with bottom field first interlacing)
I then use Tmpgenc to make PAL DVD compliant video (same interlace settings as above)
Then I used DVD lab to author dvd.
The resulting DVD shows interlace artefacts (combing in fast pan scenes) when played on PC.
No such problems playing the source dv avi or the dv avi output by vegas.
Any solutions??
Thanks,
Keith
Hi keithsebastian,
This is perfectly normal on a PC monitor and is a regular occurrence for many people.The resulting DVD shows interlace artefacts (combing in fast pan scenes) when played on PC.
Play it on your TV and it will / should be fine.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Hi daamon,
Thanks for the info. That's exactly what I'd suspected. Guess I'll go ahead and burn the DVD's.
Keith
How to de-interlace captured video without artifacts?
By krumm-krumm in forum EditingReplies: 10Last Post: 29th Sep 2011, 00:36 -
3D dvd content - convert to Blu3D content
By Smells_Like_Feet in forum Authoring (Blu-ray)Replies: 19Last Post: 18th May 2011, 07:52 -
Looking for artifacts
By Caple in forum RestorationReplies: 18Last Post: 1st Oct 2010, 20:27 -
Removing "interlace" artifacts
By gordonbennett in forum DVD RippingReplies: 2Last Post: 26th Apr 2010, 11:45 -
Question about HD to SD and interlace>progressive>interlace
By ayim in forum Video ConversionReplies: 4Last Post: 10th Dec 2009, 12:21
