why cant i burn some of my avi to CDR??? most of my avi i bruned already, but some wont burn on to an CD-R... i get the error say it can EnDTrack on Nero.. anyone know whats wrong?? i try making my avi in to zip, and ra files, but i get errors too.. so it must be the avi, anyone know how to fix this or is there a program to check if there are any problem with the avi files??
It might be the media. Try burning on to a CD-RW and see if you get the same errors.
Also, how big is the .AVI? You aren't overburning, are you?
Cobra -
nope.... no over burn.. avi files are 130mb each, and it only happens to some of the avi.. i try DVD, CD-R, and CDRW
data... its just happen to some of my avi.. so i guess its te avi files that are mess up, but i need something to fix it
Verbatim 94554 CDR vs. 94712 CDR. What's the difference?
By Puppets86 in forum MediaReplies: 12Last Post: 3rd Oct 2010, 16:31 -
Why are cdr burn rings lighter than dvdr burn rings?
By yoda313 in forum Newbie / General discussionsReplies: 4Last Post: 27th May 2010, 17:55 -
How to burn AVI files onto CDR?
By doofdoofdude in forum Newbie / General discussionsReplies: 2Last Post: 18th Apr 2008, 10:08 -
burn vob into cdr
By pcb in forum Newbie / General discussionsReplies: 10Last Post: 18th Feb 2008, 12:28 -
How Can I burn a 90 min data CDR Image to HD Folder
By SCDVD in forum Newbie / General discussionsReplies: 1Last Post: 15th Feb 2008, 19:48
