Can anyone suggest a good quality portable vcd player? Playing mp3s and CDs would be a plus. Thanks..
Results 1 to 11 of 11
this one is the best in my opinion
http://www.mp3playerstore.com/buy_it_now__/mp-2001.htm -
Don't expect quality with portable VCD players..
Napa is a good choice, has a remote too... -
There are no really good portable VCD players, unless you count those portable DVD players that are VCD-compatible. I don't have any experience with the Supertek provided in the link above, but I owned an Avex DM-5, and I currently own a Napa DAV-311.
Although I can play VCDs I've made on my own with TMPGEnc without all the stuttering problems others have experienced, I've found the portable(s) I('ve) have(had) play pressed VCDs much, much better and with a clearer picture.
If you're looking to buy a portable VCD player to play burned VCDs, you should strongly reconsider it, or revise your expectation of quality sharply downward.
<font size=-1>[ This Message was edited by: AntnyMD on 2001-11-26 06:44:36 ]</font> -
Well, I'm mainly going to play pressed CDs not burned. So I take it that the portable will work okay (I don't have much room since it's going to be a college dorm, that's why I can't really go for the Apex player since my room is stuffed with PS2 & XBOX already)
A portable VCD player should do well in a dorm room. Don't spend too much money on it.
I'm not a fan or follower of gaming consoles, but doesnt Sony PlayStation 2 support VCD? If so, you already have a VCD player without having to a) spend more money, or b) lose more dorm room real estate.
On 2001-11-29 16:52:36, Tsukiyono Omi wrote:
BTW, just curious what is DVCD?
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
A VCD pressed onto 99 minute media. -
I recommend picking up a used notebook pc. You can get a decent one for under $200. I picked up an IBM ThinkPad 760XL 166Mhz MMX, w/128MB RAM, 1GB HD, ext. floppy, internal CDROM, all for $200.
And since this formfactor (the 750, 755, 760 line was very prolific) is very common, you should not find any difficulty getting add-ons.
They have removable harddrives so you can set up a smaller capacity HD that is specifically tuned for playing VCDs.
I'm in the process of doing that right now.
Portable DVD Player vs Portable Video Player
By DJboutit in forum Newbie / General discussionsReplies: 9Last Post: 2nd Dec 2012, 17:28 -
Please suggest a simple portable USB DVD burner to purchase in the US
By suirauqa in forum DVD & Blu-ray WritersReplies: 8Last Post: 13th Jun 2010, 07:49 -
Blu-ray player Or MKV media player, please suggest!
By Xnici in forum DVD & Blu-ray PlayersReplies: 3Last Post: 8th Jun 2010, 15:15 -
Good Multi Region XVID DVD Portable player with IN's n Out's?
By iC3MAN in forum Portable VideoReplies: 0Last Post: 28th Dec 2009, 14:57 -
Suggest A Good Video Editing Software
By Jedi5 in forum EditingReplies: 10Last Post: 9th May 2008, 11:56
