  1. Hi,
    I have just bought a Sony DVD player (model: DVP-355 - think ive got that right). I have firstly been extracting the audio from movie files using Virtual Dub and then using TMPGenc Xpress 3.0 to merge the two into a MPEG-1 VCD format file.
    All goes well but when I get about into 20 minutes of the movie when watching it on my DVD player after burning to CD, it gets slightly but noticeably out of sync.
    I have noticed when I change the audio source in TMPGenc Xpress it warns me that Clip/edit and keyframe data will be reset and give the option to continue: yes (continue and do reset); no (continue but dont reset); or cancel. For the last movie I chose Yes. Would this make any diffence?
    Also, to tie up with the subject matter of whether it is a conversion or player fault, I also notice that when it goes out of sync on the player and I tap quick search (rewind/fast forward) for a split second then play, it sorts it. Any help please?
    Bizt
  2. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Hoe does it play on your computer? Is it in sync all the way through?
