  1. Banned
    Dec 2003
    I ran an integrity check on a Ghost 2003 HD Backup and it failed. I can see the files and folders that were backed-up, but for some reason it says there were errors. Here is a log of the check; can anyone tell me what I did wrong?
    ImageCheckOperation 0
    -- GHOST\GHOSTERR.TXT ---------------------------------------------------------
    Date : Mon Oct 11 16:34:55 2004
    Error Number: (437)
    Message: Cannot read from file
    Version: 2003.775 (Aug 14 2002, Build=775)
    Command line arguments: -removableMedia -wizard -chkimg,@FIND[ID:106118390]\CDR00001.GHO -ghwrap
    Active Switches :
    Spanning
    AutoName
    Sure
    ProgMode : PROG_LOCAL
    PathName : 16665 Unnamed MFT Table entry
    DumpFile : D:\CDR00002.GHO
    DumpPos : 1758494720
    File64 buffersize : 32768
    FlagImplode : 0
    FlagExplode : 2
    CloneSrc : D:\CDR00001.GHO
    BatchPartSrc : 0
    BatchPartMSrc :
    CloneDst :
    BatchPartDst : 0
    Operation Details :
    Total size.........6006
    MB copied..........2199
    MB remaining.......3807
    Percent complete...36%
    Speed..............213MB/min
    Time elapsed.......10:18
    Time remaining.....17:49
    Program Call Stack
    Generic_Abort
    DumpRead
    NTFSRead
    readFirstSeqPacket
    loadRun
    loadAttribute
    loadAttributes
    loadMFTRec
    loadMFT
    loadVol
    CheckNTFSImage
    CheckPartition2
    CheckFileIntegrity
    CopyMainline
    AttemptOperation
    sub_main
    main
    Call Stack
    0x0023b4f7
    0x0006b0af
    0x0006a35c
    0x0006a1d1
    0x0006b833
    0x00025f2d
    0x000c7eda
    0x000c7a06
    0x000c71c8
    0x000c6abc
    0x000c5edd
    0x000c4652
    0x000c3178
    0x000c27a9
    0x0009d4a2
    0x000bef69
    0x000beafe
    0x00029c41
    0x000022dc
    0x000023f3
    0x00004426
    0x0000370b
    0x00248bf8
    End Call Stack
    Start heap available: 261095424
    Cur heap available: 260898816
    Total Memory: 267124736
    Conventional Memory
    Inital Conventional Memory Size = 389552
    Current Conventional Memory Size = 320416
    Allocated
    1024 DpmiDjgpp.cpp:59
    33504 ghost.cpp:911
    64 DiskDriveAccessExInt13.cpp:107
    528 IdeDmaServerPci.cpp:132
    32768 file64.cpp:298
    Free
    80 DiskDriveAccessExInt13.cpp:93
    512 DiskDriveAccessInt13.cpp:177
    Fat details:
    NTFS details:
    NTFS Global Flags:
    contiguousWrite=1 forceDiskClusterMapping=0
    inhibitCHKDSK=1 ignoreBadLog=1 ignoreCHKDSKBit=1
    enable_cache=0 xfrbuflen=32768
    last_attr_type = 0
    NTFS volume 0:
    initialised..............1
    read cached..............N
    Selective caching........N
    flags....................Volume OK
    No drive - probably sourced from file image
    part order...............0
    version..................0x0400
    volsize..................78091964
    blocksize................512
    clusterfactor............8
    clustersize..............4096
    mftrecordsize............1024
    indexrecordsize..........4096
    indexclustperrecord......1
    bootSectorCopyOffset.....78091964
    pagefileSys..............4294967295
    bootIni..................3052
    volumeLabel..............[]
    sectorsInUse.............13661176
    totalNonCopiedBytes......0
    bytesToCopy..............0
    bitmapClusters...........298
    bitmapUsedBytes..........1220192
    estimatedClusters........298
    estimatedUsedBytes.......1220192
    clustersizeShift.........12
    blocksizeShift...........9
    mftrecordsizeShift.......10
    indexrecordsizeShift.....12
    totalRootMftRecs.........26191
    clustermap failover......N
    Boot sector details
    name....................[NTFS ]
    blocksize...............512
    clusterfactor...........8
    reservedSectorsUnused...0
    mediaType...............0xf8
    secPerTrack.............63
    numHeads................255
    hiddenSectors...........64260
    volsize_lo..............78091964
    volsize_hi..............0
    mftcluster.(lo).........786432
    mftcluster.(hi).........0
    mftmirrorcluster.(lo)...4880747
    mftmirrorcluster.(hi)...0
    clustersPerMFTRecord....246
    clustersPerIndexBuffer..1
    Cluster Allocation Map
    Start: 9761495 Length: 0 Next: 9761495
    Disk Info :
    remote.............0
    drive..............0
    sectors_used.......78091965
    estimated_used.....12300673
    pemax..............1
    Version............760
    # Ord Boot Id Ext First Num Last Used NTFS
    0 0 80 7 No 00064260 78091965 78156225 13661176 Yes
    Disk Info :
    sectors_used.......0
    estimated_used.....0
    pemax..............0
    Version............0
    Drive 128 ST340016A 3HS3SGZZ
    Int 13h
    Total Sectors 16434495
    Bytes per Sector 512
    MB 8024
    Cylinders 1023
    Heads 255
    Sectors per Track 63
    Extended Int 13h
    Total Sectors 78165360
    MB 38166
    IDE using PIO
    MB 38166
    Cylinders 16383
    Heads 16
    IDE using UDMA (Active)
    MB 38166
    Cylinders 16383
    Heads 16
    Remote Drives
    AsyncIo : 0
    NTFS MFT or Attribute Structure
    000: 80 00 00 00 08 02 00 00 01 00 00 00 01 00 00 00 ................
    016: 79 05 00 00 00 00 00 00 1F 0B 00 00 00 00 00 00 y...............
    032: 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 @...............
    048: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    064: 01 07 31 08 4E AD 31 01 08 11 08 10 01 08 11 07 ..1.N.1.........
    080: 10 01 09 11 09 10 01 07 11 08 10 01 08 11 07 10 ................
    096: 01 09 11 08 10 01 08 11 08 10 01 08 11 08 10 01 ................
    112: 08 11 08 10 01 08 11 08 10 01 08 11 07 10 01 09 ................
    128: 11 07 10 01 09 11 08 10 01 08 11 08 10 01 08 11 ................
    144: 08 10 01 08 11 09 10 01 07 11 07 10 01 09 11 07 ................
    160: 10 01 09 11 08 10 01 08 11 0C 10 01 04 11 0C 10 ................
    176: 01 04 11 09 10 01 07 11 07 10 01 09 11 08 10 01 ................
    192: 08 11 09 10 01 07 11 08 10 01 08 11 08 10 01 08 ................
    208: 11 09 10 01 07 11 07 10 01 09 11 07 10 01 09 11 ................
    224: 08 10 01 08 11 08 10 01 08 11 08 10 01 08 11 08 ................
    240: 10 01 08 11 08 10 01 08 11 07 10 01 09 11 06 10 ................
    256: 01 0A 11 07 10 01 09 11 0B 10 01 05 11 08 10 01 ................
    272: 08 11 07 10 01 09 11 08 10 01 08 11 08 10 01 08 ................
    288: 11 08 10 01 08 11 08 10 01 08 11 08 10 01 08 11 ................
    304: 08 10 01 08 11 08 10 01 08 11 08 10 01 08 11 0A ................
    320: 10 01 06 11 07 10 01 09 11 07 10 01 09 11 07 10 ................
    336: 01 09 11 07 10 01 09 11 08 10 01 08 11 07 10 01 ................
    352: 09 11 07 10 01 09 11 07 10 01 09 11 07 10 01 09 ................
    368: 11 07 10 01 09 11 07 10 01 09 11 07 10 01 09 11 ................
    384: 07 10 01 09 11 07 10 01 09 11 07 10 01 09 11 07 ................
    400: 10 01 09 11 07 10 01 09 11 07 10 01 09 11 09 10 ................
    416: 01 07 11 07 10 01 09 11 07 10 01 09 11 08 10 01 ................
    432: 08 11 07 10 01 09 11 07 10 01 09 11 07 10 01 09 ................
    448: 11 07 10 01 09 11 07 10 01 09 11 07 10 01 09 11 ................
    464: 08 10 01 08 11 08 10 01 08 11 08 10 01 08 11 08 ................
    480: 10 01 08 11 08 10 01 08 11 07 10 01 09 11 07 10 ................
    496: 01 09 11 08 10 01 08 11 08 10 01 08 11 06 10 01 ................
    512: 0A 11 02 10 01 0E 00 00 FF FF FF FF 00 00 00 00 ................
    528: FF FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00 ................
    544: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    560: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    576: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    592: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    608: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    624: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    640: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    656: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    672: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    688: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    704: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    720: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    736: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    752: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    768: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    784: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    800: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    816: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    832: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    848: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    864: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    880: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    896: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    912: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    928: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    944: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    960: 00 00 00 00 00 00 00 00 01 04 00 00 F9 0F 00 00 ................
    976: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
    992: 00 00 00 00 A8 B3 45 00 00 00 00 00 00 00 00 00 ......E.........
    1008: B4 B3 45 00 00 00 00 00 00 00 00 00 C0 B3 45 00 ..E...........E.
    1024: 00 00 00 00 00 00 00 00 CC B3 45 00 00 00 00 00 ..........E.....
    1040: 00 00 00 00 D8 B3 45 00 00 00 00 00 00 00 00 00 ......E.........
    1056: E4 B3 45 00 00 00 00 00 00 00 00 00 F0 B3 45 00 ..E...........E.
    1072: 00 00 00 00 00 00 00 00 FC B3 45 00 00 00 00 00 ..........E.....
    1088: 00 00 00 00 08 B4 45 00 00 00 00 00 00 00 00 00 ......E.........
    1104: 14 B4 45 00 00 00 00 00 00 00 00 00 20 B4 45 00 ..E......... .E.
    1120: 00 00 00 00 00 00 00 00 2C B4 45 00 00 00 00 00 ........,.E.....
    1136: 00 00 00 00 38 B4 45 00 00 00 00 00 00 00 00 00 ....8.E.........
    1152: 44 B4 45 00 00 00 00 00 00 00 00 00 50 B4 45 00 D.E.........P.E.
    1168: 00 00 00 00 00 00 00 00 5C B4 45 00 00 00 00 00 ........\.E.....
    1184: 00 00 00 00 68 B4 45 00 00 00 00 00 00 00 00 00 ....h.E.........
    1200: 74 B4 45 00 00 00 00 00 00 00 00 00 80 B4 45 00 t.E...........E.
    1216: 00 00 00 00 00 00 00 00 8C B4 45 00 00 00 00 00 ..........E.....
    1232: 00 00 00 00 98 B4 45 00 00 00 00 00 00 00 00 00 ......E.........
    1248: A4 B4 45 00 00 00 00 00 00 00 00 00 B0 B4 45 00 ..E...........E.
    1264: 00 00 00 00 00 00 00 00 BC B4 45 00 00 00 00 00 ..........E.....
    1280: 00 00 00 00 C8 B4 45 00 00 00 00 00 00 00 00 00 ......E.........
    1296: D4 B4 45 00 00 00 00 00 00 00 00 00 E0 B4 45 00 ..E...........E.
    1312: 00 00 00 00 00 00 00 00 EC B4 45 00 00 00 00 00 ..........E.....
    1328: 00 00 00 00 F8 B4 45 00 00 00 00 00 00 00 00 00 ......E.........
    1344: 04 B5 45 00 00 00 00 00 00 00 00 00 10 B5 45 00 ..E...........E.
    1360: 00 00 00 00 00 00 00 00 1C B5 45 00 00 00 00 00 ..........E.....
    1376: 00 00 00 00 28 B5 45 00 00 00 00 00 00 00 00 00 ....(.E.........
    1392: 34 B5 45 00 00 00 00 00 00 00 00 00 40 B5 45 00 4.E.........@.E.
    1408: 00 00 00 00 00 00 00 00 4C B5 45 00 00 00 00 00 ........L.E.....
    1424: 00 00 00 00 58 B5 45 00 00 00 00 00 00 00 00 00 ....X.E.........
    1440: 64 B5 45 00 00 00 00 00 00 00 00 00 70 B5 45 00 d.E.........p.E.
    1456: 00 00 00 00 00 00 00 00 7C B5 45 00 00 00 00 00 ........|.E.....
    1472: 00 00 00 00 88 B5 45 00 00 00 00 00 00 00 00 00 ......E.........
    1488: 94 B5 45 00 00 00 00 00 00 00 00 00 A0 B5 45 00 ..E...........E.
    1504: 00 00 00 00 00 00 00 00 AC B5 45 00 00 00 00 00 ..........E.....
    1520: 00 00 00 00 B8 B5 45 00 00 00 00 00 00 00 00 00 ......E.........
    1536: C4 B5 45 00 00 00 00 00 00 00 00 00 D0 B5 45 00 ..E...........E.
    1552: 00 00 00 00 00 00 00 00 DC B5 45 00 00 00 00 00 ..........E.....
    1568: 00 00 00 00 E8 B5 45 00 00 00 00 00 00 00 00 00 ......E.........
    1584: F4 B5 45 00 00 00 00 00 00 00 00 00 00 B6 45 00 ..E...........E.
    1600: 00 00 00 00 00 00 00 00 0C B6 45 00 00 00 00 00 ..........E.....
    1616: 00 00 00 00 18 B6 45 00 00 00 00 00 00 00 00 00 ......E.........
    1632: 24 B6 45 00 00 00 00 00 00 00 00 00 30 B6 45 00 $.E.........0.E.
    1648: 00 00 00 00 00 00 00 00 3C B6 45 00 00 00 00 00 ........<.E.....
    1664: 00 00 00 00 48 B6 45 00 00 00 00 00 00 00 00 00 ....H.E.........
    1680: 54 B6 45 00 00 00 00 00 00 00 00 00 60 B6 45 00 T.E.........`.E.
    1696: 00 00 00 00 00 00 00 00 6C B6 45 00 00 00 00 00 ........l.E.....
    1712: 00 00 00 00 78 B6 45 00 00 00 00 00 00 00 00 00 ....x.E.........
    1728: 84 B6 45 00 00 00 00 00 00 00 00 00 90 B6 45 00 ..E...........E.
    1744: 00 00 00 00 00 00 00 00 9C B6 45 00 00 00 00 00 ..........E.....
    1760: 00 00 00 00 A8 B6 45 00 00 00 00 00 00 00 00 00 ......E.........
    1776: B4 B6 45 00 00 00 00 00 00 00 00 00 C0 B6 45 00 ..E...........E.
    1792: 00 00 00 00 00 00 00 00 CC B6 45 00 00 00 00 00 ..........E.....
    1808: 00 00 00 00 D8 B6 45 00 00 00 00 00 00 00 00 00 ......E.........
    1824: E4 B6 45 00 00 00 00 00 00 00 00 00 F0 B6 45 00 ..E...........E.
    1840: 00 00 00 00 00 00 00 00 FC B6 45 00 00 00 00 00 ..........E.....
    1856: 00 00 00 00 08 B7 45 00 00 00 00 00 00 00 00 00 ......E.........
    1872: 14 B7 45 00 00 00 00 00 00 00 00 00 20 B7 45 00 ..E......... .E.
    1888: 00 00 00 00 00 00 00 00 2C B7 45 00 00 00 00 00 ........,.E.....
    1904: 00 00 00 00 38 B7 45 00 00 00 00 00 00 00 00 00 ....8.E.........
    1920: 44 B7 45 00 00 00 00 00 00 00 00 00 50 B7 45 00 D.E.........P.E.
    1936: 00 00 00 00 00 00 00 00 5C B7 45 00 00 00 00 00 ........\.E.....
    1952: 00 00 00 00 68 B7 45 00 00 00 00 00 00 00 00 00 ....h.E.........
    1968: 74 B7 45 00 00 00 00 00 00 00 00 00 80 B7 45 00 t.E...........E.
    1984: 00 00 00 00 00 00 00 00 8C B7 45 00 00 00 00 00 ..........E.....
    2000: 00 00 00 00 98 B7 45 00 00 00 00 00 00 00 00 00 ......E.........
    2016: A4 B7 45 00 00 00 00 00 00 00 00 00 B0 B7 45 00 ..E...........E.
    2032: 00 00 00 00 00 00 00 00 BC B7 45 00 00 00 00 00 ..........E.....
    Image Devices
    Key A:
    Path A:
    Desc
    Type Floppy
    Key C:
    Path C:
    Desc [-VPSGHBOOT-]
    Type Disk
    Disk 0
    Offset 21302190
    Key D:
    Path D:
    Desc [GHOST_001]
    Type CD
    Key @LFO1:1
    Path 1:1
    Desc []
    Type NTFS
    Disk 0
    Offset 64260
    Key @CD-R1
    Path @CD-R1
    Desc OPTORITEDVD RW DD1203
    Type DVD
    -- GHOST\GSCRIPT.TXT ----------------------------------------------------------
    [ImageCheckOperation]
    AlreadyProcessedFile = YES
    BeginTimeParam = Mon Oct 11 16:22:49 2004
    EndTimeParam = Mon Oct 11 16:34:56 2004
    ExecutionStateParam = ExecutionFailed
    FileIdParam = 106118390
    ImageOnRemovableMedia = YES
    PathParam = \CDR00001.GHO
    SourceFingerprintParam =
    UseLFOParam = NO
    WindowsPathParam = D:\CDR00001.GHO
    -- GHOST\ARGS.TXT -------------------------------------------------------------
    -removableMedia -wizard "-chkimg,@FIND[ID:106118390]\CDR00001.GHO" -ghwrap
    -- AUTOEXEC.BAT ---------------------------------------------------------------
    @echo off
    SET PATH=C:\GHOST;C:\
    SET PROMPT=To return to Windows, type ghreboot and press Enter.$_$p$g
    SET TZ=GHO+06:00
    if "%CONFIG%" == "WINDOWS" goto WINDOWS
    LH \MSCDEX.EXE /D:cd1 /D:cd2
    MOUSE.COM
    CD \GHOST
    GHWRAP.EXE
    goto EOF
    :WINDOWS
    \GHOST\GHREBOOT.EXE
    :EOF
    -- CONFIG.SYS -----------------------------------------------------------------
    [MENU]
    menuitem=GHOST,Run Norton Ghost Dos Operation
    menuitem=WINDOWS,Return to Windows without running Norton Ghost
    menudefault=GHOST,3
    [GHOST]
    LASTDRIVE=Z
    DEVICE = \ASPICD.SYS /D:cd2
    DEVICE = \OAKCDROM.SYS /D:cd1
    [WINDOWS]
  2. You said your backup was on the hard drive. But all the "computerese" indicates you were attempting a CD backup. I have never had a data verification failure backing to the hard drive or DVD, but plenty of them backing up to CD. Try CD-RW, I always had better luck with them.
    If it works, don't fix it.
  3. Banned
    Dec 2003
    There isn't anything that I said in my post the would make one assume that I backed the image up to my harddrive.
    The backup is on a DVD-r.
  4. Sorry, the "2003 Ghost HD backup" threw me. I assumed you meant a backup to a second hard drive, I do this as well as the achival copy to DVD. When I get a virus or something I use the "HD copy" to restore, it is faster. The archival copy is in case the second drive konks out. Note: I have had successful integrity checks that didn't restore when needed. I always do a "restore" off the DVD to check it. If it fails, I still have the second hard drive backup to save me. I'm paranoid about backups, I would be totally screwed if I lost all the work I have done.
    Since that is resolved, your problem is most likely a DVD media problem. If you go to the DVD media section you might find comments about the media you are using. To tell you the media I use is the best would start a war, but some are definitly better than others. Good Luck.
