Results 1 to 9 of 9
  1. i've tried to look for an answer to this, but haven't found anything yet.
    i have been taking DVD-RWs burned by by Philips TiVo unit, encoding the video with ffmpeg to .avi (using MPEG-4, mencoder) files. then i've been transferring the .avi files to my PC and editing out the commercials with VirtualDub.
    is there a way to edit the .avi's and cut out the commercials on the Mac without having to use the PC at this stage?
    i haven't had much success trying to edit the video before encoding to .avi, and the whole demuxing is more work than what i'm doing now.
  2. wait....will QTP do this for me?
    i'd easily spend $30 if it definitely will.
  3. Member WiseWeasel's Avatar
    Jan 2003
    Silicon Valley, CA, USA
    It will, but I'm not sure the resulting AVIs will play on a PC... Anyone?
    I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
    Oct 2003
    Canada
    I assume the DVD recorder creates standard DVDs with mpeg2 files on them. First copy the vob files from the DVD-RW to your hard drive, open them up in MPEG Stream Clip (you need Apple QT Mpeg2 Component) cut the frames you don't want and save as a new mpeg file (this won't re-encode the video).
    Next open the mpgs in ffmpegX and convert to mp4 or whatever.
  5. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    they will, as long as you view them with the PC counterpart of Quicktime
    Jul 2001
    usa
    MPEG Stream Clip
    is this a new ap? does it work pretty well?
    pants on, pants off, pants the floor.
  7. MSC seems like a nice alternative method.
    i'll try it out.
    but it's good to know that QTP will let me edit as well.
    ffmpeg has the benefit of allowing you to create a queue for encoding.
  8. QTP takes my avi file, lets me cut out the commercials, but when i try to save it, it spits out a .mov file with no audio. i tried selecting the avi divx option, but then the program hangs as though it were trying to reencode.
    is there a way to get QTP to simply do direct stream copy of an avi file without making it a .mov?
  9. Member WiseWeasel's Avatar
    Jan 2003
    You could try the 'Movie to AVI' export option, instead of the Divx AVI one...
