How can i transfer the video data i have in my ccd-v9 sony camcorder onto my PC.
I tried attaching it to my video card but i can't access it anywhere on my comp.
Does your camcorder have a firewire (sony i-link) port? Does your computer have a firewire port? That's the best way to link a DV camcorder to a PC. You can get a firewire card for your PC if necessary.
"Art is making something out of nothing and selling it." - Frank Zappa -
i got a panasonic digital video cam last week
it said it would connect via usb on the box but it turned out that you could only transfer stills via the usb connection
so i went out and bought a £10 firewire card from www.ebuyer.co.uk and it worked within minutes -
Yea seems to be the only thing to do is get a firewire card, I guess thats wat ill do. thx
Als, look into the following apps for "capture" from a DV cam (in no particualr order):
WinDV
AVI_IO
DVIO
Scenalyzer Live
As well as editing packages like Adobe Premiere (I use v6.0).There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
complete camcorder virgin looking for a (up to)$850 camcorder
By rocketman122 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 28th Aug 2010, 11:34 -
Which is good HDD camcorder or DV camcorder?
By tapal in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 16th Sep 2008, 04:09 -
Analog Camcorder to Digital Camcorder Cable Question
By bradnwa in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2008, 13:47 -
Will cheap new Hi8 camcorder output better than old, worn Hi8 camcorder?
By ErikL7 in forum RestorationReplies: 7Last Post: 2nd Sep 2007, 07:26 -
MiniDV Camcorder or DVD Camcorder
By psxiso in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 9th Jul 2007, 18:13
