I'm trying to make a backup of ANTZ. With MTR 2.0.2, I get
DVD Error: Failed vob 1 size test.
The Error pops up 4 times, I click OK then MTR continues for a bit then tells me it's complete. DVD2oneX shows almost completed then gives an error:
Alert: Error adjusting the IFO file. It does not match with the VOB file.
Next, I tried DVDBackup and it worked, but now that I'm using DVD2oneX, it's taking forever. Right now with 11% done, it telling me there are 15 hours left. Hold the press! After over two hours, DVD2oneX just crashed. <sigh>.
Help!
MTR has problems such as this on certain strangely-mastered DVDs. We haven't heard of any problems with that title, but perhaps it's a bad production run or something. I would try giving DVDRemaster a try, or just trying to locate another copy of that movie.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
DVDRemaster failed almost as soon as it started on the files. Looks like the DVD is too damaged to backup. Thanks for the suggestions....off to find another copy. Seems like old animated dvds are generally in bad shape.
Nero - Compliance test failed? whats up w/ this?
By BRYAN_B28 in forum Authoring (DVD)Replies: 11Last Post: 2nd May 2012, 01:13 -
Nero Error Msg - 'Prepare Session Failed'
By Dieseldog in forum Authoring (DVD)Replies: 0Last Post: 19th Dec 2011, 06:38 -
testing thecoalman's suggestion of [code=php] test [/code] ... FAILED!
By vhelp in forum TestReplies: 1Last Post: 10th Jun 2009, 01:15 -
FAVC - Error (Fix VTS Sectors failed!)
By tim_ver in forum Newbie / General discussionsReplies: 1Last Post: 31st Jan 2009, 01:16 -
MTR can't read DVD... READ ERROR: Can't Open IFO.
By strathq in forum MacReplies: 16Last Post: 16th Jun 2007, 23:04
