Results 1 to 9 of 9
  1. i use ad-aware pro and spy sweeper for a while and they use to do just fine..... but i notice now on 2 of my computers (and a couple of friends computers) that i can run both programs more than once and certain spyware will show right back up i even discon from the internet and run both programs and del the spyware but can run the programs again and its like they never got del...... also these are the spyware that hijak your browser also can anyone give me a better spyware removal program????
    PS.... already try spybot search and destroy and that doesnt work either
  2. Banned
    Sep 2004
    Inner Circle of Thought
    Try a program called hijack this.
    It will work, but you must be careful or you will screw things up.
  3. Originally Posted by bazooka
    ...and you can download it from the link in my previous post.
  4. Member glockjs's Avatar
    Feb 2004
    the freakin desert
    yeah hijackthis did it for me. go to spywareinfo.com and post your hijackthis log and you'll be able to get help
    PhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500
  5. Or ... if you have WinXP, use system systore to a date that you're sure you didn't have the spyware.
    Don't forget to make sure system restore can only touch the C drive and not the other drives. If you have some files that may or may not be touched during the system restore, move it to the other drives.
  6. Use Spybot Resident too. A combination of that and ad-aware will take care of 99% of common spyware. Also try windows startup inspector, found at www.spychecker.com . Also go to run and type msconfig. Set your boot settings to Diagnostic Startup and run those apps after a reboot, or just schedule a boot-time run.
    Jul 2002
    Up in yo' bitch.
    Also... be sure to check your prefetch folder as well as temp folders for any occurrences of the .exe files.
  8. Member Jayhawk's Avatar
    Mar 2003
    Pensacola, Florida
    I think one of your problems might be the process rather than the programs you are using. Try this way:
    Turn off System Restore
    Clean out your temp files, IE cache
    Boot into Safe mode without networking
    Run Adaware, Spybot, and a virus program of your choice (all with udated definition files)
    Reboot into Normal Windows
    Turn on Restore
