I have 3 mpeg2 files and 2 of them are both encoded with 5.1 AC3 audio while one of them is 2.0 AC3. I can't fit all 3 on a DVD because of the one file with 2.0 makes it out of standard. Is there any way I can flag the stereo file to 5.1 so I can burn it all? Is that possible?
Redo it.
just put the 3rd one in its own title set and you can mix all three on a dvd
wont putting the one vid as a seperate track screw with the chapter select? bcause it has its own title now? it would ruin the transition of the video kinda, no?
no - not if you author it properly
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 11:23 -
MPEG4-AVC (H264) + AC3 -> Divx + AC3?
By thomas_fogh in forum Video ConversionReplies: 12Last Post: 1st Nov 2008, 20:25 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 19:22 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 10:24 -
H264 + AC3 + AC3 --> VOB - What is wrong with my command line?
By olik in forum ffmpegX general discussionReplies: 5Last Post: 3rd Feb 2008, 07:06
