Many months ago I created a 3GB AVI file that I wish to delete. When I try to delete it I get an error message that says the file is in use by another program. I have tried going into safe mode and then to command prompt to delete it but command prompt doesn't recognize my extra D: drive. At lease it doesn't let me switch to it under "cd" change directory. Anyone have a suggestion rather than formatting the drive?
Russ
Try this:
http://personal-computer-tutor.com/abc3/v31/vic31.htm
or this:
http://www.tweakxp.com/tweak1467.aspx
MAKE SURE you back up your registry beforehand, just in case.... -
Well thanks!! Looks like just the answer I was looking for.
Russ
What's a good program that lets you choose end file size for AVI?
By THRobinson in forum Video ConversionReplies: 6Last Post: 5th Apr 2010, 20:42 -
MKV to AVI program, hardsubbing program, adding subtitle to DVD Flick
By projecttemp in forum Video ConversionReplies: 1Last Post: 21st Sep 2009, 08:42 -
mkv - deleting multiple audio tracks & subtitles - then convert to avi
By fme008 in forum Video ConversionReplies: 2Last Post: 24th Mar 2009, 06:12 -
Best Mac program to make 4 X 6 pix from avi file
By MacPCConsultants in forum MacReplies: 9Last Post: 23rd Mar 2008, 20:34 -
What program to open up a .tv file?
By Gandolff in forum DVB / IPTVReplies: 0Last Post: 12th Sep 2007, 12:28
