I have a season of tv eps recorded in xVid. I want to fit them on 2 dvds, but I am over by about 400-500 mb. So I was wondering what program could I use to reencode them all and decrease the bit rate a little bit to reduce file size.
Thanks, there any program with batch changing?
Results 1 to 14 of 14
Well I am putting 13 episodes per disc, so I cannot use DVD Shrink because I am pretty much just putting the files onto the disc. My DVD player can play xVid and DivX. Correct?
re-encode just a few to avoid making them all look bad
Top and tail them (cut the start/end titles in Vdub) and/or demux and drop the bitrate of the audio then remux.
Originally Posted by rishid
I don't think standalone player support xvid or divx, but I could be wrong -
some do
i second thisOriginally Posted by monzie
you may need nandub or vdubmod to handle the vbr mp3 audio
cutting off the titles and the end credits has worked for me in the past with the sopranos on 350mb episodes it turned out i skimped off the excess 50 mb by removing the start sequence and the credits off 2 episodes -
If you decide to cut the titles and credits you can use VirtualDub in "Direct Stream Copy" mode to avoid reencoding the video and audio. You can only cut on a key frame though.
this works very well for cutting also https://www.videohelp.com/forum/viewtopic.php?t=240575&highlight=
what kind of player do you have? do you need a certain audio format? do you author the disc a certain way?Originally Posted by monzie
https://www.videohelp.com/dvdplayers.php?DVDname=&Submit=Search&divx=1Originally Posted by 12 gage
WMV Modification Without Reencode
By frmys in forum Video ConversionReplies: 4Last Post: 1st Sep 2011, 06:24 -
Reencode
By mentme33 in forum Newbie / General discussionsReplies: 9Last Post: 17th Dec 2010, 14:08 -
How do I reencode WMV to Xvid?
By sgsiaokia in forum Video ConversionReplies: 4Last Post: 26th Oct 2008, 14:46 -
Does divx author reencode Divx and xvid files?
By Onceler2 in forum DVD RippingReplies: 4Last Post: 26th Aug 2008, 19:16 -
DivX reencode
By Ogilvy in forum LinuxReplies: 1Last Post: 3rd Jul 2008, 15:17
