I got a NEC ND-1100A Dell OEM burner from my friend. It has a 10GE firmware, it seems that it only burns all discs at 2.4X. It should burn at 4X. There are lots of firmwares for the non Dell version, but the newset for the Dell is 10GE. Is there a way for me to use any non Dell OEM firmwares?
I have the same drive. I've searched and haven't yet found any firmware upgrades for it.
I would suggest the following as Ive had an ND-1100A from from HP (it did burn at 4x though), anyway, theres a flash to make it dual and some other crap..bit setting too I think. check out:
http://club.cdfreaks.com/forumdisplay.php?s=&forumid=86
and
http://forum.rpc1.org/index.php?sid=92c5bf5cea50cb9cef9e8fce42247da0 -
you can burn any nec 1100 firmware on it. go here
http://www.firmware.fr.st/ -
I have been wondering about this for some time.
I'm in the same boat. Things burned fine at 4X before I did the firmware upgrade.
Has anyody had any luck doing the firmware change on this Dell drive?
I'd like to try, but a 2.4X drive is better than a pooched one.
Caliburn
Dell with a NEC 2100AD DVD+R writer - flash update to write to DVD-R?
By DirtBikeMike in forum ComputerReplies: 5Last Post: 30th Sep 2010, 12:24 -
Mouse - OEM or Retail?
By alintatoc in forum ComputerReplies: 6Last Post: 6th Dec 2009, 03:31 -
Retail vs OEM
By bryankendall in forum ComputerReplies: 5Last Post: 3rd Dec 2009, 12:32 -
windows 7 - oem or retail
By alintatoc in forum ComputerReplies: 29Last Post: 24th Oct 2009, 01:05 -
daewoo dv-1100a region free hack
By noblegirl in forum DVD & Blu-ray PlayersReplies: 2Last Post: 6th Jun 2009, 19:18
