After a layoff I am back to capturing VHS tapes to convert to DVD.
No real problem capturing 20 to 25 minute tapes to the hard drive as Uncompressed AVI. Using TMPGEnc 2.5 to encode as MPG. I am having trouble using Virtual Dub to frame serve to TMPGENc.
I Deleted Virtual Dub 1.4 and installed 1.6 , perhaps I need to go back to 1.5.10 (Stable Version). Installed AVIframeclient support via auxsetup.exe, then used the proxyon.reg to enable the proxy support.
I can use TMPGEnc to create the mpg file from the avi without using the frameserver. (not sure about out of sync audio yet) If I use the frameserver I get moasic type image. Not sure what is buggered up so I am posting while I try to work through this issue.
I use to know how to attach an image also.
Results 1 to 1 of 1
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 13:48 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 15:36 -
Some questions regarding Virtual Dub
By smackyourfupa in forum DVD RippingReplies: 3Last Post: 5th Nov 2007, 06:00 -
Virtual Dub in asp
By dizzy123 in forum ProgrammingReplies: 13Last Post: 19th Sep 2007, 06:00 -
Virtual Dub Mod
By OG24 in forum Newbie / General discussionsReplies: 11Last Post: 8th Aug 2007, 15:36
