I get the audio but the screen is just green when I try playing it. The codec says DivX 4. Anyone know what's wrong?
Results 1 to 10 of 10
I did what you said "jyn999" , the rendering says that it's ok... and when i open it with GSpot, the soud seem ok but the screen is green and the program shut down in seconds (WMP, divxplayer, bs playerquictime,...).... the same that when I dont open it with GSpot....
any other ideas???
anyone?
PLEASE!! -
Maybe the video part of your AVI file is just a green screen
Can you download another copy? -
Try uninstalling any old versions of the mpeg 4 codecs and reinstall the latest Divx and Xvid.
Or maybe your DIVX codecs are corrupt. You might try reinstalling them. Also, if you installed a codec pack this can happen.
Try VLC media player. It may be able to play the files without the 'green'.
EDIT: And what junkmalle said. -
thank everyone so much for their help.... spécially for Redwudz... cause the VCL player solved the problem ..... I dont know what it was but i can now play the files!
thanks everyone! -
I believe VLC uses it own codecs. Which probably confirms that your other codecs are corrupt. But glad it works.
Avidemux 2.5.6 Green screen problem
By ABBrittain in forum Newbie / General discussionsReplies: 0Last Post: 28th Feb 2012, 06:49 -
How to use green screen with video?
By MitchStevens in forum Newbie / General discussionsReplies: 4Last Post: 23rd Jun 2009, 19:33 -
By MitchStevens in forum Video Streaming DownloadingReplies: 1Last Post: 23rd Jun 2009, 09:44 -
Where to buy video lighting/green screen in UK?
By tikigod19 in forum Newbie / General discussionsReplies: 0Last Post: 15th Jan 2009, 04:19 -
Help on music video text and green screen
By wan2no in forum Newbie / General discussionsReplies: 3Last Post: 10th Nov 2007, 22:36
