I have an old monitor and I'm giving it to a friend but the color is way to light on it even with the brightnes turned all the way down, I used this monitor with my daughters computer before that had a Geforce video card so I used the Nvidia program to make it darker but my friend has an older computer with a crappy video card, I really need a free program that will make it darker for them.
Thanks All !
Lookup a program called I THINK powerstrip. Its a PC app that lets you control this stuff. I dont know a freeware solution.
Monitors have a brightness & focus knob on the back that you can turn. Sometimes its inside & on the back but most old ones have them on the back outside or under a door.
it's a HP P1110 21 inch, I guess there are alot of people with the same problem.
I just hooked it up to my computer and used a program called QuickGamma and it helped alot.
Thanks for your replys !
How do I make my movies look '3d' on my monitor?
By Stealth3si in forum Newbie / General discussionsReplies: 12Last Post: 12th Jul 2011, 01:21 -
need free program to test LCD monitor
By moniia in forum ComputerReplies: 3Last Post: 26th Feb 2011, 14:26 -
light capturing program for vistaview saber DA-1N1-I
By studur in forum Capturing and VCRReplies: 4Last Post: 15th Jul 2009, 07:43 -
SOLVED Vegas 8.0, how can I make a light bulb flashing?
By sdsumike619 in forum EditingReplies: 2Last Post: 25th Apr 2009, 18:21 -
What program can I used to Capture what i'm doing on the desktop (monitor)?
By Goldman123 in forum Newbie / General discussionsReplies: 3Last Post: 27th May 2008, 15:02
