I recorded a movie from satellite into mpg video and recorded way beyond the end of the movie.
I've done this before, but can't remember. How can I go in and cut out just the movie. I know it's simple and you don't have to re-encode it when doing this...just can't remember how![]()
Results 1 to 16 of 16
Ok, I got to this point File=>MPEG Tools=>Merge & Cut and load up the mpg video, but where does it let me cut out what I don't want.
I have done this before a loooooooooooonnnnnnnngggg time ago and just keep forgetting
There is a guide for this sort of thing, click here.
"Art is making something out of nothing and selling it." - Frank Zappa -
Thanks that worked!
Now another question...what is the best way to cut out commercials from video recorded from the tv? Seems like the guide you sent me to is for cutting out chunks of video I would want to keep.
Thanks! -
You use the same procedure. Just keep cutting out everything you want to keep, leaving the commercials behind. This usually is the best way, as your video doesn't get re-encoded with TMPGEnc Plus.
Hello. -
Originally Posted by Tommyknocker
So, doing it this way will leave me with several mpg files...correct? Then just merge all those into one? -
Not exactly. For Instance, say there are three commercial breaks in your video. You would add your source video to the TMPGEnc Plus Merge & Cut tool four times. 1, for the beginning to the first commercial break. 2, for the first commercial break to the second. 3, for the second break to the third break. 4, for the third break to the end of the video. All these segments you would save to one file.
Hello. -
This is where you're loosing me. I thought when I selected 1 area to cut I then had to hit the run button and cut it. Can I select 3 different areas to cut before cutting?Originally Posted by Tommyknocker
Sorry, but I'm just not clear on how to do it. -
Originally Posted by darkcyber
Does this make it any clearer?
Hello. -
If you know how to use AviSynth and frameservice from Virtual Dub to TMPGEnc Plus, your editing could get more precise.
Hello. -
I'v never used Avisynth. I 've used Virtual Dub, but not for cutting stuff like this.Originally Posted by Tommyknocker
Look at the guides in the Tools section at left. I studied it once when I looking for something to do, and picked up the basics quickly. Give it a try.
Hello.
Cut Out Segments Of Video Using Womble MPEG Video Wizard DVD
By luckyace in forum Newbie / General discussionsReplies: 2Last Post: 4th May 2017, 04:46 -
how cut MP4 video
By kyro32 in forum Newbie / General discussionsReplies: 2Last Post: 23rd May 2010, 16:31 -
Video Editing problem with Final Cut and Flip Video! Help!
By caputr in forum MacReplies: 2Last Post: 22nd Jun 2008, 12:52 -
Is there anyway to know whether a video has been cut or not?
By RiverDD in forum EditingReplies: 6Last Post: 6th Jun 2008, 16:31 -
I want to cut the audio from the video, only remain video?
By awaisuk in forum EditingReplies: 2Last Post: 20th Nov 2007, 08:17
