I have a Karaoke VCD disk and I want to copy but the original VCD is 727MB and the destination disk have only 700MB. Can someone tell me how to do that? Thank you.
Hello,
If its already in vcd format (with a folder called mpegav and others) than you can just do a normal disc copy.
VCDs can fit more than 700mb. It's a slightly different recording method. But it will work just fine.
Just make sure you copy it as a vcd and not a data disc.
It is worked fine when i am using copy disk( I am using data disk before). Thank you very much.
How to record HD TV?
By iRecycle in forum Capturing and VCRReplies: 19Last Post: 28th Nov 2014, 18:46 -
How can i record from the tv to a tv recorder?
By sluv2 in forum DVB / IPTVReplies: 6Last Post: 2nd Feb 2011, 18:10 -
How to record from this site?
By lmkmip67 in forum Video Streaming DownloadingReplies: 2Last Post: 29th Aug 2010, 14:17 -
Record from TV to My Computer ?
By sat-jokar in forum Newbie / General discussionsReplies: 11Last Post: 2nd May 2009, 10:05 -
how can i record vcd on imac?
By Ade007 in forum MacReplies: 4Last Post: 9th Aug 2008, 14:34
